LS3 Cam upgrade
I'm planning on upgrading the LS3 cam to:
TSP Stage 2 N/A LS3 229/244, .629/.615, 112 LSA Camshaft These are the supporting parts I plan to replace: - Pushrods - Timing chain and upgrade to 3 bolt - Melling High-Pressure Oil Pump - Timing Cover and water pump gaskets and front crankshaft seal - Rocker arm trunnion upgrades - Camshaft Retainer Plate and Bolts Also doing headers/exhaust. I'm at 66k miles and all stock, but is there anything else I should strongly consider? or are any of those options too overkill? |
![]() ![]() Drives: 2012 Camaro 2SS/RS Vert LS3/M6 Join Date: Aug 2021
reach out to a guy on here Andrew Cammer. he can help you get what you need to maximize your setup! Im guessing your a manual with the LS3 cam info, correct?
Dual Valve Springs and you are good to go.
![]() Drives: 2012 camaro ss Join Date: Sep 2018
Cadi or Johnson lifters!
GPI Powered
2&THEHIT
Drives: 5th Gen Camaro; 5th Gen Ram 3500 Join Date: Mar 2018
And a tune to make it work
| Tags |
| cam, ls3, tsp |
