Old 02-16-2025, 04:14 PM   #1
1Camaro2SS
1Camaro2SS's Avatar
Drives: 2013 Camaro ZL1 M6
What causes Roto-Fab filter to deform like this?
I just purchased a 2013 ZL1 and was going to clean the air filter until I realized it’s worse that I thought so now I’m debating to buy a new one instead but does anyone know what might have caused this filter to deform this way? I’m wondering if it was poorly installed and mis handled or if the supercharger can deform these. Thanks
1Camaro2SS is offline   Reply With Quote
Old 02-16-2025, 04:27 PM   #2
larry_g
larry_g's Avatar
Drives: 2014 1SS/1LE
The wrinkles aren't as much of a concern as the actual damage to the mesh. I would replace it.
Sent from my Pixel 8 Pro using Tapatalk
Old 02-16-2025, 04:37 PM   #3
1Camaro2SS
1Camaro2SS's Avatar
Good call, I will replace it.
Old 02-16-2025, 04:40 PM   #4
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Yeah, someone before you probably messed it up doing something with it to damage the mesh like that. As for the filter element looking a bit crinkled, all the K&N's I have had looked like that a little. I just installed it so that area doesn't show. Replace that one for sure.
Old 02-16-2025, 05:21 PM   #5
tartagliazl1
tartagliazl1's Avatar
Drives: 2013 zl1 vert
I have a nice 5” rpm intake for sale. Haha
22% lower/ 2.5 upper/ 2” headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 1300/ dsx aux kit/ 103mm throttle body/ big gulp 5” intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2” lid spacer/ cnc,milled ported heads/ brick mod/BMR toe and trailing arms/ 781hp 748 tq SAE @17.3lb on a loaded dyno.
tartagliazl1 is online now   Reply With Quote
Old 02-16-2025, 09:21 PM   #6
Thraul Returns
Drives: 2013 zl1
The reason this happens is simple, being lazy when trying to install the filter. The washer fluid reservoir filler neck and main ground is effectively in the way when you try to fit up the filter to the intake. The way to properly install is to remove the hose clamps on the intake, disconnect the hose and back it out a bit first then move the filter into place and re-secure hose/hose clamps.
-Blake J.
Thraul Returns is offline   Reply With Quote
Old 02-17-2025, 10:15 AM   #7
Brutale arancia
Brutale arancia's Avatar
Drives: 2013 ZL1 Camaro
I've gone through many K&N filters on 2-strokes. They just don't hold up that well. A new one always looked like that after a few cleanings. Under a hood and on paved roads is much less abusive so I would guess that one is pretty old.
Brutale arancia is offline   Reply With Quote
Old 06-06-2025, 08:51 AM   #8
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
Get the non-oiled one and just replace it when needed
