Old 01-29-2010, 05:13 PM   #1
TommyTSquared
TommyTSquared's Avatar
Drives: RSSS
LS3 manual trans fluid change - less noise, etc?
I've read the manual, I know it's a sealed transmission, I've done a search. Don't post a reply if you're not going to answer the question please.
Ok, I remember reading a thread (which I cannot find now) about a few people changed their transmission fluid and now have a smoother shift with less noise. I've also read that the fluid bought from GM is just Dex 3 ATF re-packaged. So here are my questions to those that have changed their transmission fluid:
Which fluid (brand, was it dex 3, or is there a weight) did you use?
Did you also change the filter for whatever reason?
Have you noticed a change (better/worse/none) in shifting after changing your fluid?
Thanks in advance.
TommyTSquared is offline   Reply With Quote
Old 01-29-2010, 09:13 PM   #2
mtcwby
High on "The Camaro Life"
mtcwby's Avatar
Drives: 2010 2SS, IOM, LS3, Vortech, LG cam
Send a message via AIM to mtcwby
The Tremec manual transmission is not sealed. There is a drain plug and a fill plug on the passenger side of tranny. There is no filter. It takes 4.2 qts.
You can use Royal Purple Synchromax with good luck. Shifting also seems to be smoother. The Chevrolet dealer that I go to is who recommended the RP Synchromax to me.
The GM Manual Trans. Fluid recommended for this is not just Dex III. It is dexIII plus alot of other additives to help with engaging the synchronizers. Regular DexIII will not work very good and you will notice difficulty shifting.
"The democracy will cease to exist when you take away from those who are willing to work and give to those who are not."-Thomas Jefferson------Going Strong at 39,250 miles
mtcwby is offline   Reply With Quote
Old 01-29-2010, 09:36 PM   #3
TommyTSquared
Drives: RSSS
Sweet, thanks for clearing that up. I reread the manual and I don't know where I got sealed from (maybe another thread?). Do any of the transmissions come with filters? The manual doesn't specify to which transmission it is referring to when it says "Pan Removal and Filter Replacement" .
I will look into the RP fluid. Thanks for clearing everything up! One post is all it takes with the right information !
Old 01-29-2010, 09:44 PM   #4
mtcwby
mtcwby's Avatar
No problem, You were probably reading about the Automatic trans. It is sealed and has a filter in the pan.
Have you changed your Diff fluid yet? I put RP GearMax in mine and it works great. Takes just a hair over 1 qt. and you don't need the limited slip additive with the RP. It already has additives in it.
Old 01-29-2010, 09:47 PM   #5
TommyTSquared
Drives: RSSS
You know what they say about great minds... went and picked up some RP 75w90 the other night with the hopes of doing it this weekend. Then we went from 66 down to the teens with some snow/ice .
Once I get the trans fluid I can just make a day (or rather an hr or so) out of this!
Old 01-29-2010, 09:58 PM   #6
Russell James
Russell James's Avatar
Yup, go with Royal Purple Synchromax in the Trans. I found some at a Napa store near me. Pricey though - about $18 per qt.
You'll need some way to pump it up into the fill hole. It is tight up next to the trans. I bought an el cheapo hand pump at an auto parts store. They usually have them near the gear lubes. A good time to disable the skip shift while it's up in the air.
I've found the RP Synchromax to be a little smoother shifting than the OEM fluid. Which is what I wanted and to switch to a synthetic.
Old 01-29-2010, 10:04 PM   #7
SSOOCH
Camaro SL,UTs
SSOOCH's Avatar
At what mileage would you suggest changing the fluid? Thanks.
Old 01-29-2010, 10:15 PM   #8
Russell James
I changed mine at 25 miles. I wanted synthetic in there, and I like the results of the RP Synchromax. If your shifting perfectly smooth, you really don't need to. I'm in really cold temps and wanted a synthetic in there that is a hair better when cold.
I've changed out the trans fluid to synthetic in all the 6 speed manual cars I've bought over the years.
Old 01-29-2010, 10:21 PM   #9
mtcwby
mtcwby's Avatar
My Chevy dealer has the Synchromax for only $12 per quart.
As soon as you can, you won't regret it and you'll wonder why you didn't do it sooner.
Old 01-29-2010, 10:33 PM   #10
SSOOCH
Camaro SL,UTs
SSOOCH's Avatar
Thanks!
Old 01-29-2010, 10:43 PM   #11
TommyTSquared
Drives: RSSS
Skip shift eliminator is on my list of what to buy with the next paycheck (and left over from car payment) and I will be sure to install when I get to changing the fluids. Thanks for the tip with the pump, I will be picking one up whenever I find the Synchromax.
Old 01-30-2010, 05:35 PM   #12
Ject
aka Patrick
Ject's Avatar
Drives: '10 Camaro 2SS '04 Silverado
Send a message via Yahoo to Ject
I know this isn't exactly on topic but Just as a reference, I believe us Automatic users use the RP Max ATF, correct?
Current Modifications: Your average Bolt-ons & Suspension Upgrades
GForce Engineering: 9" Rear End, Strange Pro Iron Case w/Moser Nodular 3.70:1 Detroit locker, 3.5" Solid Drive Shaft
Ject is offline   Reply With Quote
Old 01-30-2010, 05:45 PM   #13
jimpfromwv
jimpfromwv's Avatar
Drives: 1968 camaro ss, 2010 camaro1ss
I changed mine at 3000 miles and used RP synchromax. Shifts are smoother but man that stuff stinks!
jimpfromwv is offline   Reply With Quote
Old 01-31-2010, 12:06 AM   #14
Russell James
No I don't think so. The auto needs a Dex VI, and I don't see that spec on the RP ATF.
Amsoil has a Dex VI called Fuel Efficient Low Viscosity.
What ever you pick, make sure it says Dex VI for the automatic. That really shouldn't need a change though for quite a while.
Can't Decide - Auto or Manual attymf Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 213 02-22-2022 08:48 PM
Noise at 3000RPM 6 speed Manual Unique Auto Depot Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 1 01-09-2010 04:30 PM
Sealed Transmission?? Transmission fluid doesn't need change until 150k miles? DevilKnightFalcon Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 34 12-07-2009 07:32 PM
LS3 Specs revealed: GM's 436hp Sick 6.2L LS3 TAG UR IT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 28 07-30-2009 07:02 PM
LS3 + Manual = New Gears? ZZcamaro V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 17 03-16-2009 07:55 AM
