Old 03-01-2025, 10:00 PM   #1
Conquest1
Drives: 2011 Camaro 2SS 6M
which mufflers?
I have a 2011 SS 6 speed. As of now 100% stock. I'd like it just a bit louder without being too loud or raspy. I find if my cars are too loud I'm reluctant to get into it hard in town and attract too much attention.
Which mufflers are an easy swap to get a bit better flow and a bit more sound....but not too much..?..:-)
Conquest1 is offline   Reply With Quote
Old 03-01-2025, 10:55 PM   #2
SS_Dave
SS_Dave's Avatar
Drives: 2011 Camaro 2SS/RS
Honestly, I'd recommend rather than changing mufflers, get long tube headers, a CAI, and have it tuned. With stock mufflers on an M6 with headers, you'll find that it's not too loud until you really press it. Even then, someone running somethign like Borla Atak is gonna be louder. No drone either. I've been pretty happy with that, though I may swap mufflers and get louder eventually. And with this setup, you'll get an actual performance gain, where you won't get much of anything with just mufflers.
SS_Dave is offline   Reply With Quote
Old 03-03-2025, 03:43 PM   #3
RickyC
Drives: 2010 2SS RS
install a set of SOLO catalytic converters. You will be happy.
RickyC is offline   Reply With Quote
Old 03-03-2025, 06:51 PM   #4
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
^^^ This is a great way to go, a bit more power and sound. Or if you are in a state with no emissions checks like some of us, do a cat delete, you will pick up some more sound, but no more performance. And stay away from Flowmaster mufflers, they drone like crazy. Ask me how I know..
Old 03-04-2025, 08:14 PM   #5
TheBrightSide
Drives: 2010 Chevy Camaro 2SS coupe (MT)
Honestly, a muffler delete or cheap axleback with small mufflers, would be fine. Assuming you still plan on keeping your factory exhaust manifolds/headers, the stock H-pipe and resonators will do a mild amount of keeping the exhaust tamed down.
Or like someone said, you can just go straight to long tubes, although you’ll need a few extra parts for that job. Another alternative that’s not too common unless you’re in a strict emissions state, is to get shorty headers and maybe find some off-road down pipes/cat delete connection pipes.
With that said though, if you end up getting full-sized rear mufflers with fiberglass packing, I would just get the stock resonators and factory H-pipe removed. You can look up clips of the H vs X-pipe to compare the two distinctions. The H-pipe exhaust tone sounds more “clappy”, like a truck exhaust setup; while the X-pipe sounds more gnarlier and sportier, but somewhat raspier.
TheBrightSide is offline   Reply With Quote
Old 03-05-2025, 08:51 AM   #6
ABM2SS
Drives: 2010 SS M6 ABM
a muffler delete
I did the Muffler Delete with the MBRP Pipe Kit. Just right for me. Louder nice deep tone but not too loud at idle. And gives the nice popping sound when you let off the gas at speed.
ABM2SS is offline   Reply With Quote
Old 03-06-2025, 12:14 AM   #7
InFiD3ViL
InFiD3ViL's Avatar
^^^He's right.
You may be tempted, as some of the Flowmasters really do sound amazing, but they almost all drone something fierce.
Old 03-06-2025, 11:06 AM   #8
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
^^^He's right.
lol, thanks sir! But yeah, my Flowmaster American Thunder ZL1 catback DID sound good, but man o man the drone as InFiD3ViL said was mind bogglingly disgusting for sure!!! After about 2 hours of cruising, you would have a severe headache!! And all their chambered mufflers are that way. I had a set of Dynomax's on their that weren't too bad before the Flowmaster catback.
Old 03-06-2025, 01:57 PM   #9
pyroguy
Started#gottalovethatblue
pyroguy's Avatar
Drives: ABM #832
Mufflers? What are those?
As others have said, if you're looking for a little performance advantage, go with long tube headers and a tune. That will create the biggest advantage for you. It will get louder sounds and increased performance.
If you're not interested in getting the car tuned and just want to change the exhaust, check out Solo Performance. They have a couple of Canadian locations and can help install it for you if you're near them. For a manual exhaust you would be best with an axle back setup. They are a muffler delete, but have J pipes to kill off any drone that you might experience with just a pure muffler delete.
Check out my build thread
Old 03-12-2025, 01:09 AM   #10
InFiD3ViL
InFiD3ViL's Avatar
Yeah, Solo is definitely something I would consider if I was doing this from scratch again. They sound great, have drone removing technologies, and best of all, their prices aren't as insane as most of the other aftermarket exhaust companies are.
Old 03-21-2025, 11:37 AM   #11
wuanameruns
Drives: Chevrolet Camaro SS
Long tubes, no cats, and axle back mufflers
wuanameruns is offline   Reply With Quote
Old 03-21-2025, 09:11 PM   #12
rdavis
Drives: 2012 SS
I went a different route than most. stainless works long tubes with cats & NPP mufflers.
For me it is absolutely perfect. Semi quiet with the valves closed with zero drone. Very rowdy with valves open, but still very little drone. With this system you have a choice, loud or quiet. Of course, this system is a little pricy, but to me was well worth it.
2012 2SS/RS 6speed, Howards asa cam on 113lsa Stainless works LT's, NPP exhaust, Z28 Cai, 3.91 gears. Tuned by Blue Thunder 2 racing Lubbock Texas.
rdavis is offline   Reply With Quote
Old 03-21-2025, 10:14 PM   #13
witenite
witenite's Avatar
Drives: 2010 2SS non RS
LS3 M6 stock... If so cut the mufflers off and replace mufflers with straight pipes. Cheap and easy for more sound.
witenite is offline   Reply With Quote
Old 03-22-2025, 07:52 AM   #14
Joe.G
Joe.G's Avatar
Drives: 2014 2SS/RS 6SP Ashen Grey
I run Stainless works LTH, with Hi Flo Cats and stock NPP with Mild to Wild controller. I like it.
GM 3.91/TrueTrac OEM ZL1 Rims, 6 Piston Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, GC Aluminum DS,Stainless Works Ceramic LTH/HiFlo Cats, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace, Moroso Catch Can,SCT X4 Dynosteve,Remote Clutch reservoir,Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights
AeroForce Dual gauge/Autometer pillar mount.
Joe.G is offline   Reply With Quote
