Old 03-04-2025, 05:51 PM   #1
TheBrightSide
Drives: 2010 Chevy Camaro 2SS coupe (MT)
Upgrading to a 2012+ Tremec TR-6060?
I have a 2010 2SS manual coupe, with the factory bone stock Tremec TR-6060 trans. It supposedly has the weaker, defective main output shaft, as well as the initial brass synchronizers and blocking rings, before they were upgraded/revised for all 2012+ V8 manual models, I believe.
My question is if I can just simply toss in a 2012 or 2013-2025 6MT from any manual SS, and be done with it? I can’t remember when exactly the parts revision was done, but if I want to maybe avoid the guesswork, I can just aim for a 2013-2015 manual trans instead.
I figured if I built the 2010 SS manual trans, that could be an option too; as I don’t have every piece of equipment and machinery that I might need, in order to DIY the trans swap from my living space/garage. I’d have to account for labor and maybe a new clutch and flywheel, probably main rear seal, if I just bought a used trans and paid for a swap to be done.
Oh, and I recalled there being some additional output shaft tail bearing(?) that was on other TR-6060’s, that could also be added?
TheBrightSide is offline   Reply With Quote
Old 03-05-2025, 10:38 AM   #2
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
Here is a link to a TR6060 rebuild from the Corvette Forum. I think the biggest tool requirement is the bearing splitter.
https://www.corvetteforum.com/forums...d-rebuild.html
Rockland Standard Gear used to sell the kit to add the bearing, and I think others may have gotten it from Liberty. Here is a thread I did about it years ago.
https://www.camaro5.com/forums/showthread.php?t=394512
Old 03-24-2025, 09:30 AM   #3
TheBrightSide
So, I went through your links and info (thanks for all the hard work put in for us), and looked for other teardowns and builds/re-builds.
I still wanted to know if whether the main output shaft OEM part number, would be the revised one (GM P/N# 19260477). I put it into Rockauto as a 2015 Camaro SS manual, for example, and found that OEM part as the only supplier available.
I figured that since only the 2010’s (and maybe some 2011 year models?) had the supposed weaker/defective main output shaft, that it would be beneficial to replace it with a better, revised part? I figured it could go along with the tail shaft support bearing.
Old 06-07-2025, 08:37 AM   #4
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Check into Tick Performance they have a good rebuild program for the trans and several upgrades for it they even have billet shift forks..
Orange Krush II
Old 06-09-2025, 07:02 AM   #5
CamaroCracka
I read a lot about it and from what I could gather, it was only early 2010s that had the improperly heat treated shaft. Since it was a defect in creating the part that was corrected, no new part number was issued and it does not affect a shaft you would get today. If you are really worried about it, have Tick rebuild it with a 9310 shaft and your trans will be good for 1000+ HP. RPM also offers the service, or at least they used to, but they are a bit pricey.
I've broken a ZL1 axle and twisted a driveshaft in half. My trans is definitely not the weak link.
Old 06-17-2025, 06:06 PM   #6
TheBrightSide
What kind of driveshaft were you running? Just curious. What's recommended?
output, swap, tr6060, transmission, tremec
