Old 03-05-2025, 03:52 AM   #1
niceguy
Drives: 2013 Camaro
Front Spoiler Replacement 2013 Camaro Dusk Edition
I would appreciate your help guys, thanks in advance.
I have a 2013 V6 Dusk Edition Camaro that needs a new front spoiler.
Can someone point me to a after market part that will fit my model.
I did some research and found the part in the link below but I am not sure
https://parts.gmparts.com/product/gm...TKBvavApGuXOIq
niceguy is offline   Reply With Quote
Old 03-05-2025, 12:26 PM   #2
Trawz
Trawz's Avatar
Drives: 2013 Camaro 1LE
Finding an original that came with the 1LE, Dusk Edition, and Hot Wheels Edition is extremely hard because they discontinued them a few years ago.
When my splitter got damaged from a deer incident, I went with the T4 from ACS Composites.
https://acscomposite.com/products/ac...rYmUMYdxkSonL5
It matches about 80-85% the same. The mounting method and mounting locations are different and it sits slightly lower then the original.
Plus, it is fiberglass and not ABS plastic. So any future hits will chip the gel-coat or crack/shatter it.
It looks original when installed and has been working great for me.
Pretty easy and straight forward install.
I also got it with all the "options" as in the undertray and side deflectors.
2013 1SS/1LE
Corsa Extreme cat-back, Speed Engineering LT Headers with black ceramic coating, C7 Z06 Front Brake Upgrade, Custom Mishimoto Oil Cooler, BMR Tunnel Brace, Custom Dual Mishimoto Oil Catch Cans, MSD Plug Wires, Mishimoto Radiator and Hoses, Melling High Volume/High Flow Oil Pump, Improved Racing Oil Pan Baffle Kit, Improved Racing Oil Pressure Bypass Delete, Improved Racing Oil Pick-up Tube Clamp.
Trawz is offline   Reply With Quote
Old 03-05-2025, 05:56 PM   #3
niceguy
Drives: 2013 Camaro
Problem is my car is a V6 not an V8 model that the spoiler suggested states it fits
Old 03-05-2025, 09:07 PM   #4
witenite
witenite's Avatar
Drives: 2010 2SS non RS
Maybe the T5 from ACS?
https://acscomposite.com/products/ac...-lt-rs-only-v6
witenite is offline   Reply With Quote
Old 03-10-2025, 06:37 AM   #5
niceguy
Drives: 2013 Camaro
Originally Posted by witenite View Post
Thanks......I will contact this company for confirmation
Old 03-10-2025, 07:33 AM   #6
niceguy
Drives: 2013 Camaro
One more thing, is this seller trustworthy
Old 03-10-2025, 08:59 AM   #7
MSgt O
MSgt O's Avatar
Drives: 2012 Camaro 2SS/RS Vert LS3/M6
yes, ACS is a great company! Lead time is a little long sometimes, but they make fantastic pieces!
MSgt O is offline   Reply With Quote
Old 03-10-2025, 12:33 PM   #8
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
One of the best out there!
Old 03-10-2025, 12:40 PM   #9
Trawz
Trawz's Avatar
This is true.
My T7 splitter took 3 months to ship.
2013 1SS/1LE
Old 03-11-2025, 04:39 AM   #10
niceguy
Drives: 2013 Camaro
Another question guys.
For any of you who bought one these spoilers, did you install it, did you have to drill holes, how many holes.
Old 03-11-2025, 08:46 AM   #11
MSgt O
MSgt O's Avatar
I did. I also bought the under piece as well, and I drilled and bolted ALL the holes with stainless self locking small bolts and fender washers. So like maybe 25 holes all together? Im sure that was overkill. but since I had the front end off, it was pretty easy
