![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 2LT/RS Join Date: Mar 2015
Hood strut support
What are you all using for your hood strut lift support? Any suggestions? Mine has gone bad and is in need of replacing. I have the TPIS adapter bracket for my GM strut tower bar for my early 2010 Camaro. I cannot remember if I ever replaced the strut 7-8 something years ago or if I reused the same one. Are all struts made the same in order to accommodate this? Thanks in advance.
2010 2LT/RS
ZL1 Appearance package, Flow Master American Thunder Cat Back Exhaust w/ QUAD TIPS, K&N Typhoon CAI, Ported VMAX TB, OEM GM Brembo Brakes Package w/ Hawks Carbon Ceramic Pads, Night Owl Halo Kit (WIFI), Rear Oracle Blue LED Bowtie, Oracle Ghosted Painted Side LED Markers, Silver Sided Gills, OEM Satin Camaro Fuel Door, OEM Strut Tower Brace, Detroit Speed Engineering 1.5" Lowering Springs, Koni Orange STR.T Struts, Z28 rear LCA's, Black Magic rear 32" sway bar, 1LE front sway bar w/ DSE end links, Aluminum Blend Door, Evil Energy Catch Can. |
Oh and on a side note... I may want to go with a chrome or a blue color version to match my under hood color theme. I saw this version on Amazon... however it states it is compatible for the 2015-2024 Camaro... whatever that means...
https://www.amazon.com/TENKIDOM-Comp...GKF?gQT=2&th=1
2010 2LT/RS
I just replaced mine with OEM when it went bad. RPI and Phastek sell the pre painted aluminum covers to go over the OEM struts.
#4 | |
Not a bad idea thanks!
2010 2LT/RS
I just bought a new one off amazon and the cover from rpi and it works great
David Vianu
2010 Synergy Green 1LT |
#6 | |
That does look good!
2010 2LT/RS
#7 |
Just ordered a strut cover from RPI and an OE strut from Rock Auto. Looking forward to the installation
2010 2LT/RS
#8 | |
![]() Drives: 2010 Chevy Camaro 2SS coupe (MT) Join Date: Jan 2024
But as far as the hood strut replacements, I’m not picky; I go with whatever’s cheap and available. OEM is perfectly fine too, I guess. I usually buy random generic aftermarket replacements on Amazon or eBay. Lately though, idk if it’s the fitment of the Amazon branded hood strut, but it’s gotten slower and doesn’t feel like it’s “broken in”. It also feels like the strut isn’t exactly the right size (off by a mm or so). |
#9 | |
Its not a strut brace. It is a strut bracket and adapter that was used for the early 2010 Camaros without the pre drilled holes in the strut towers. They no longer carry them from what I see. Adapters are used on each side along with the bracket on the strut side. Here is a pic of mine.
2010 2LT/RS
#10 |
I received my strut sleeve yesterday after I placed my order over a month ago. Apparently there is a 45 day lead time.... Even though I placed the order through Rpidesigns.com... they outsourced it to https://americanbrotherdesigns.com
They did a great job! ... pics below...
2010 2LT/RS
#11 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 CGM 2SS/RS LS3 Swapped A6 Join Date: Sep 2016
#12 | |
Nice! Did you install it yet?
2010 2LT/RS
#13 | |
![]() Drives: 2010 Chevy Camaro 2SS manual coupe Join Date: Dec 2023
Looks like you’re using the OEM style 11+ factory front strut bar/brace, so I was wondering how you got them to mount on the rounded surface (11+ models have a “flattened” section, with threaded holes). |
#14 | |
There was no template. I eyeballed it ha! Made sure it was where it needed to be using the undersided curved adapters that TPIS provided and made my measurements then marked the areas that needed to be drilled. As for the strut bar.. yes I am using the OEM style... back in South Florida... I received a coupon for $150 off parts from Sawgrass Chevrolet... and purchased the strut bar for the same price. Got it for free basically then had it painted at Maaco in the HotWheels Edition color. Only thing I did was repaintd the mounting ends in GM silver. The TPIS kit came with the bolts/nuts etc....
2010 2LT/RS
