![]() Drives: 2011 Camaro 2SS/RS Join Date: Jul 2021
Help me guess
I seem to have a bit of an oil leak. For the life of me, though, I can't see where it's coming from. I can see it a bit on the side of the block, across the bottom of the heads from back to front. And I have some wetness down the trans bell housing.
I was kind of thinking valley cover, but it's clean all around front and sides where I can see. Thought maybe oil sending unit, but I can't see the damned thing. For reference, the following have been done and recently, so I'm confident about them. - Valve covers. - Front main - Oil pan seal - Rear main (new clutch) |
#2 | |
#3 | |
![]() Drives: 2012 camaro ss Join Date: Sep 2018
GPI Powered
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 CGM 2SS/RS LS3 Swapped A6 Join Date: Sep 2016
Only decent sized oil leak I have had on this car was right after I had my valve covers removed. Apparently the gasket on one side had slipped while putting the cover back on. When I took it off (Fel-Pro Blue gasket) I noticed the thing looked huge compared to before I installed it, like it had stretched somehow. Replaced with another and been fine since.
![]() Drives: 2011 Camaro 2SS/RS Join Date: Nov 2023
Buy yourself an oil dye kit and a black light. Take the guess work out of it.
2011 SS/RS K&N Cold Air Intake, Borla Atak Cat Back, Ferrada CM1 Wheels, ZL-1 front spoiler, JSD strut tower brace, Elite Engineering catch can, Baer Rotors & Pads, Stop Tech SS Brake Lines. More to come...
