![]() Drives: 2015 LT Join Date: Mar 2025
Problem with sputter now worse/ stalls
My 2015 LT has about 51,000 miles. Recently it started to run rough right after I fill up for 10 seconds. Now it takes two times to start it after fill up and it runs rough for about 10 seconds. Also ot has always sputtered a bit once in awhile at a red light. Now my dash has a light. E7A, E7B, and E78. I think it must me a fuel issue but I don't know what it is. Anybody have any experience or idean about this? The plugs are now and it had the sputter at stops before the plugs.
![]() ![]() Drives: 2015 Z/22 Join Date: Aug 2015
Don't suppose you can read/monitor the O2 sensors? Or your fuel trims? Wonder what they're showing.
