Old 03-20-2025, 04:50 PM   #1
ABQ505
Grey Ghost
Drives: 5th Gen V6
Window jammed / frozen.
I did an advanced search in this sub and came up empty, hence the thread.
When I arrived at work, I hit the driver side "up" switch, and my window proceeded to "stagger bounce" to the full bottom position and would of course not come back up.
I replaced the whole regulator and guide package less than two years ago, so this is just extremely annoying.
I can hear the regulator/motor moving when I hit either position switch, but it might be stripped and just aimlessly turning.
Another thing I noticed when I pulled the panel was that on the way down, something caught the interior side of the glass and left a uniform scratch on the glass.
Any thoughts or advice appreciated! Thanks. -J.
ABQ505 is offline   Reply With Quote
Old 03-22-2025, 07:32 AM   #2
Joe.G
Joe.G's Avatar
Drives: 2014 2SS/RS 6SP Ashen Grey
Window possibly came off the track, Only way to really get an idea is to pull the door panel and go from there.
GM 3.91/TrueTrac OEM ZL1 Rims, 6 Piston Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, GC Aluminum DS,Stainless Works Ceramic LTH/HiFlo Cats, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace, Moroso Catch Can,SCT X4 Dynosteve,Remote Clutch reservoir,Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights
AeroForce Dual gauge/Autometer pillar mount.
Joe.G is offline   Reply With Quote
