Old 03-25-2025, 12:16 PM   #1
SS_Dave
SS_Dave's Avatar
Drives: 2011 Camaro 2SS/RS
2014 SS 1LE sway bars
Regarding fitting SS 1LE sway bars to a 2011 SS, I'm guessing the rear would work if I update lower control arms to say BMR that can go with older or newer sways, correct? What about front? Any fitment issues?
SS_Dave is offline   Reply With Quote
Old 03-25-2025, 06:04 PM   #2
Joe.G
Joe.G's Avatar
Drives: 2014 2SS/RS 6SP Ashen Grey
No issues in the front correct on the rear.
GM 3.91/TrueTrac OEM ZL1 Rims, 6 Piston Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, GC Aluminum DS,Stainless Works Ceramic LTH/HiFlo Cats, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace, Moroso Catch Can,SCT X4 Dynosteve,Remote Clutch reservoir,Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights
AeroForce Dual gauge/Autometer pillar mount.
Joe.G is offline   Reply With Quote
Old 03-26-2025, 10:16 AM   #3
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
If you corner hard, which is kind of the point of putting in 1LE bars, you need to upgrade the front links to the 12mm (2012 and later) units.
