![]() Drives: Chevy Camaro SS Join Date: Sep 2024
LS3 ticking
I just installed a BTR Stage 2 V2 NA cam (221/24x)
Replaced: Delphi LS7 Lifters, Dual Valve springs, Hardened pushrods 7.425", BTR Stage 2 V2 NA Cam I am having this ticking noise, friend said it sounds like a fuel injector, I tightened the header bolts and still get the noise on the passenger side of the car. Oil pressure at 215 degrees temp is running just under 30 PSI, nothing out of the ordinary. https://youtube.com/shorts/-7VhVMiXSOc |
Update: Not fixed, I unplugged the passenger side fuel injectors 1 by 1 to see if the sound went away on any, it didnt.
Could it be the spark plugs not being fully tightened Edit: Not the spark plugs they are all fully tight Last edited by Leased_SS; 03-29-2025 at 01:35 PM. |
![]() ![]() Drives: 2013 Camaro 2SS AGM Join Date: Apr 2020
Did you use a pushrod tool to confirm length?
2013 2SS GPI built & tuned 415, spec'd by Andrew Cammer. GPI ported intake/tb/heads, Tooley springs, CHE trunnions, Callies rotating assembly, Diamond pistons, GPI SS3 VVT, ATI 10% ud damper, Circle D 3800, Kooks ceramic coated lt's with green cats, Mishimoto rad & oil cooler, Derale trans cooler, Holley efi rails. DSS driveshaft, trutrac with 3.91's, G-Force renegades, Hendrix solid cradle bushings Bmr: poly diff bushings, Strange adjustable coilovers, sub frame connectors, ZL1 npps, controlled with a vac pump & mac boost control solenoid.
Turning wrenches
Drives: 2011 Camaro SS By Berger 11BC21 Join Date: Jul 2009
Check out post 14
https://www.corvetteforum.com/forums...ammed-ls3.html You might need to go back to 7.4 push rods. I would recommend not running that engine until you figure this out. Have you asked your tuner what they think?
Sold-2006 Pontiac GTO
M6 1 of 475 353rwhp 353rwtq Sold-2000 Camaro SS A4 Hardtop #867 of 8913 1 of 103 Bright Rally Red Hardtop SS A4 in 2000 1 of 25 and only SIM Camaro By Berger in 2011 year, 2011 Camaro 2SS/RS M6 By Berger #11BC21 |
#6 | |
#7 | |
Turning wrenches
#8 |
#9 |
Figured out the issue. The flange of my headers 3 out of 4 the welds on them busted off causing an exhaust leak (heard in the original video).
So I was right about the headers being tight but didnt realize they busted where it was welded together |
#10 |
Turning wrenches
What brand are the headers? Did you have the length of the pushrods measured just in case?
