Old 01-30-2010, 08:36 AM   #1
2SuperSport
2SuperSport's Avatar
Drives: 69-SS/RS 10-2SS/RS 02-GT
Track / Gear question?
Lets say i have 2 stock camaros both with a quarter mile time and speed of 13.5 sec @ 108.44 mph
Now lets say i throw a 3.73 in one car and a 4:10 in the other. What changes?
2SuperSport is offline   Reply With Quote
Old 01-30-2010, 04:56 PM   #2
2SuperSport
wow 34 hits and no responses
it wasn't a trick question i promise
i am assuming one gear will produce a higher trap speed and a lower time while the other may have the opposite affect
what do you guys think? my first upgrade will be a gear. i just wanted some insight on 1/4mile performance.
Old 01-30-2010, 05:03 PM   #3
nuptualnemesis
NuptualNemesis
nuptualnemesis's Avatar
Drives: Silver 1SS M6 - 480hp 11.57/120.79
You may or may not get a better ET. It depends on torque and horseower at the end of the quarter stock vs. new gear. The RPM will probably be higher but the MPH may be the same. It also depends on the difference between the two gears and whether it is an A6 or M6. Weight of the car, tires and rims also affects benefit of new gear
A radical 4.50 rear end will definitely improve the ET but not necessarily the MPH. MPH may be controled by horsepower.
nuptualnemesis is offline   Reply With Quote
Old 01-30-2010, 05:10 PM   #4
2SuperSport
my mind has been racing thinking about this question:
2 drivers of equal skill
2 camaros with the same performance
but with different gears (4:10 and 3:73)
who will come out ahead in the 1/4mile?
Old 01-30-2010, 06:03 PM   #5
DarricSS
DarricSS's Avatar
Drives: '10 Camaro SS
If you are racing for E.T. with the weight of the vehicle I would say the car with the 4:10 would win...
2010, SIM, 2SS/RS, LS3, CGM Stripes
DarricSS is offline   Reply With Quote
Old 01-30-2010, 06:16 PM   #6
Vinz68
Vinz68's Avatar
Drives: 68,69,72&10 Camaro's 12 CTS-V
I agree.
Vinnie
Vinz68 is offline   Reply With Quote
Old 01-30-2010, 11:27 PM   #7
speedster
SST...
speedster's Avatar
Drives: SST Camaro 2010
It will come down to how much traction you can support off of the line. These cars have 6 speed transmissions, so once you are halfway through first gear it won't make very much difference. It also depends on if the 4.10 has to shift one extra gear before the end of the 1/4. That may actually slow it down.
Old 02-24-2010, 01:04 PM   #8
My2SS/RS
My2SS/RS's Avatar
Drives: 2010 2SS/RS M6
In my M6 I hit the trap at almost redline in 3rd gear (113.55). So if the gear was changed to 4.10 I may lose some time if I now had to shift into 4th. Auto trans maybe not. Having a 108 trap prior to change may not cause this issue
My2SS/RS is offline   Reply With Quote
Old 02-24-2010, 02:05 PM   #9
the one with 4.10's would win
Old 02-24-2010, 07:25 PM   #10
nhra stocker
nhra stocker's Avatar
Drives: 69,10 camaro 71 chevelle
In a 4000 lb car you need low gears to get it out of the hole unless your having traction issues. A great 60 ft time is the most important part of having your best E.T.s. But as mentioned above having to shift the M6 and get out of the power range could hurt ya.
2010 Camaro SS RS M6 Bone stock 12.58 at 110mph http://www.camaro5.com/forums/showpo...&postcount=263
1971 Chevelle SS 454 365hp NHRA C/SA 10.73 at 122
1969 Camaro (427 ZL-1 clone) M-22 being built
1982 Siverado 4x4 454 Mud truck stock class 3.66 sec in 150' of mud
nhra stocker is offline   Reply With Quote
Camaro on Top Gear chewy4ce 5th Gen Camaro SS LS LT General Discussions 234 03-22-2010 03:14 AM
Rear End Gear Question Badger V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 8 01-09-2010 01:11 PM
Richmond Dragway Track Rental Nov 13th in Va GMRULZ USA - Southeast 2 11-15-2009 08:34 AM
Question about double clutching Muscle Master General Automotive + Other Cars Discussion 4 02-05-2009 09:27 PM
