Old 03-31-2025, 01:12 PM   #1
tartagliazl1
tartagliazl1's Avatar
Drives: 2013 zl1 vert
Head swap now popping from exhaust
I just completed my cnc head swap and now I’m getting a loud pop from the exhaust. Can’t figure out what’s going on. No cel, new plugs, can’t find a vacuum leak, injectors are firing, no strange noise. It’s only when idling. When i put a light load it goes away. Has anyone experienced this?
22% lower/ 2.5 upper/ 2” headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 1300/ dsx aux kit/ 103mm throttle body/ big gulp 5” intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2” lid spacer/ cnc,milled ported heads/ brick mod/BMR toe and trailing arms/ 781hp 748 tq SAE @17.3lb on a loaded dyno.
tartagliazl1 is offline   Reply With Quote
Old 04-01-2025, 12:12 AM   #2
Dega Man
Drives: ZL1
Sounds like you might possibly have an exhaust leak or an exhaust valve leak, hopefully it's not the latter.
Dega Man is offline   Reply With Quote
Old 04-01-2025, 06:01 AM   #3
tartagliazl1
i found it, it was a shattered spark plug on cylinder 5
Old 04-01-2025, 02:01 PM   #4
Dega Man
Drives: ZL1
Awesome, I am happy you found the issue and was not anything worse.
Old 04-01-2025, 03:56 PM   #5
ZMEnow
Drives: ZL1, 2013, tri-coat-red, manual
About 90% the issue with unusual misfires, popping, etc. on the Z’s. It’s just hard to believe you bumped the plug enough, or over tightened to crack it. Also they seem to run ok WOT..
ZMEnow is offline   Reply With Quote
Old 04-01-2025, 04:04 PM   #6
tartagliazl1
I think the plug was defective. I pregapped them and didn’t notice anything. Must of had a hairline fracture.
Old 04-01-2025, 05:01 PM   #7
ZMEnow
Cheap fix, pita though..
Old 04-01-2025, 05:24 PM   #8
tartagliazl1
I’ll tell you what tho. The popping scared the crap out of me. I was like what did i F up.
