Old 04-05-2025, 09:14 PM   #1
rednecks70
Drives: 2013 AGM ZL1, '70 Chevelle 454
What Manual Trans Fluid?
Tried doing a search but having issues. Is Royal Purple Synchromax good? I plan on doing 4 to 5 track days this year but I don't push my car that hard. Thanks!
2013 ZL1, M6, AGM, CAI, 1 7/8 Kooks Headers, 10% OD Pulley, ID1050 Injectors, 575 RWHP
rednecks70 is offline   Reply With Quote
Old 04-05-2025, 09:53 PM   #2
ZMEnow
Drives: ZL1, 2013, tri-coat-red, manual
Never had and issue with the GM fluid as trans has a cooler..
ZMEnow is offline   Reply With Quote
Old 04-05-2025, 10:40 PM   #3
Jeff_SS
"Cam Only"
Jeff_SS's Avatar
Drives: 2013 Camaro SS
Redline D4 is the way to go
2013 AGM Camaro 2SS/RS M6 | LSA Blower, 2.5" pulley, 10% lower, FIC1000's, Fore Innovations Twin Pump fuel system w/ Flex Fuel, CMS Custom Grind Cam, Kooks 1 7/8" headers w/ catless off-road pipes, NPP Exhaust, 3.91's, JLT ZL1 Intake, Prospeed Heat Exchanger, Monster S Series Triple Disc Clutch | Pfadt Suspension, 1LE Sway Bars | DSS 1000hp axles | Mickey Thompson ET Street R 305/45/18 |
Tuned by Ryne @ CMS E85: 734rwhp/674rwtq
Jeff_SS is offline   Reply With Quote
Old 04-06-2025, 08:50 AM   #4
Joe.G
Joe.G's Avatar
Drives: 2014 2SS/RS 6SP Ashen Grey
Alot of people talk highly of Redline D4 and Ill probably try it next. I run Amsoil Sig series ATF and I am happy with it.
GM 3.91/TrueTrac OEM ZL1 Rims, 6 Piston Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, GC Aluminum DS,Stainless Works Ceramic LTH/HiFlo Cats, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace, Moroso Catch Can,SCT X4 Dynosteve,Remote Clutch reservoir,Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights
AeroForce Dual gauge/Autometer pillar mount.
Joe.G is offline   Reply With Quote
Old 04-06-2025, 09:00 AM   #5
Annatar
Annatar's Avatar
Drives: ZL1 six speed manual
The timing of this thread could not be more appropriate.
The owner's manual says GM part number 88861800, but I'm in Europe and would prefer not to pay exorbitant shipping and customs fees. What could I use as a suitable replacement?
And is 88861800 really 75W-90 in disguise, or is it genuinely something else?
Annatar is offline   Reply With Quote
Old 04-06-2025, 09:12 AM   #6
Joe.G
Joe.G's Avatar
Choose one of the ones listed above and you will be fine, when I drained my factory fill it was clearly an ATF type fluid. ATF is what I have been running in my Camaros since the Worls Class T5 came out in 1988 in the F Body.
Old 04-06-2025, 09:30 AM   #7
Annatar
Annatar's Avatar
The problem is that all of those are only available in the United States, and are U. S. domestic brands, that's why I was asking what it actually is.
I have acess to Valvoline, Castrol, Liqui Moly... all the global brands. Most of the brands which advertise on "YouTube" or in TV shows like "Power Nation" are U. S. only.
Yeah, but which kind? There are different types of ATF...
Old 04-06-2025, 08:07 PM   #8
rednecks70
Thanks everyone!!
Old 04-06-2025, 08:48 PM   #9
Joe.G
Joe.G's Avatar
I believe it's Dexon3 but don't quote me on that .
Old 04-08-2025, 03:58 AM   #10
NZZL1
NZZL1's Avatar
Drives: 2013 BRM ZL1 Camaro M6
AC Delco 10-4033 = GM 88861800 is OEM manual transmisson oil (looks like ATF) but I think Redline D4 is better than OEM
https://www.amazon.com/Genuine-Fluid.../dp/B00BK7M1EK
AC Delco 10-4034 = GM 88862624 is OEM differential oil 75W-90 that includes friction modifier
https://www.amazon.com/Genuine-GM-88.../dp/B00GTJD5RG
NZZL1 is offline   Reply With Quote
Old 04-08-2025, 12:23 PM   #11
VRZL113
VRZL113's Avatar
Drives: 2013 VR ZL1, M6
Why do you think Redline D4 is better than OEM?? Do you have data to show this?
#3257 | 485whp 526wtq | K&N 63-3079 | Gates K080660HD (Green Belt) | ACDelco UPF48R | ZL1 Addons Wicker Bill | Mild2Wild
VRZL113 is offline   Reply With Quote
Old 04-08-2025, 02:37 PM   #12
acammer
GPI Sales Consultant
acammer's Avatar
Drives: 2011 Camaro 2SS SGM
Personal experience with my own car, as well as a few other local cars I interact with regularly. Redline improved both cold and hot shift quality.
Got a question about a GPI product? Feel free to shoot me a message!
acammer is offline   Reply With Quote
Old 04-09-2025, 09:49 PM   #13
J35Y2
Drives: 2010 Chevy Camaro 2SS manual coupe
Literally any kind of standard viscosity spec ATF (Dexron III, Mercon V, ATF+4) will do fine in any Tremec TR-6060. The optimal viscosity the trans likes is somewhere around 7-8 cs t(@ 100C), for any kind of gear oil/MTF or ATF, DCTF you plan to use in the TR-6060. You can technically even run the low viscosity (LV) spec ATF (Dexron VI, Mercon LV), but it might be prone to less wear protection at high temps, since it’s less viscous (~6 cst @ 100C).
The later Tremec TR-3160’s actually run LV ATF just fine apparently. I’ve done a few trans fluid changes on some Ford Shelby GT350’s, with Valvoline Max Life ATF and they do pretty good. I figured they’d probably do better if they went with regular viscosity ATF, but Tremec R&D’d it, so…. And for the Getrag MT-82 in the 2011+ Mustang GT manual models, they seem to all take any DCTF (dual clutch ATF) just fine. I don’t think I’d trust ATF in an MT-82, but apparently people have run Royal Purple Synchromax, which is like a higher visc/weight ATF.
I believe the OEM GM “manual” trans fluid (actually ATF) that Chevy/AC Delco made for the 5th gen Camaro manual (TR-6060), is conventional and not full synthetic. Aside from that, that’s probably my only opinion and decision to not run it. It could MAYBE do well with high heat and shearing down, but FULL synthetic oil products always give me more peace of mind.
GL-4 75w-80 is the spec that Tremec should’ve released, and with a thinner viscosity than most typical MTF’s. Instead, they decided to release some GL-4 75w-85 MTF that’s super hard to shift with, on cold starts. BG Synchroshift II is probably the best GL-4 75w-80 MTF/gear oil that I’ve ran in my TR-6060 manual trans, since it’s a little less thicker than most other same spec gear oils.
J35Y2 is offline   Reply With Quote
Old 04-26-2025, 03:18 AM   #14
Annatar
Annatar's Avatar
Man I love the people on this forum; the 5th generation Camaro community is one of the most knowledgeable communities in the world, and one can just tell that there is so much passion in it. I'm amazed, really, I am. Don't discount us just yet!
So, for the differential, I ended up using Ravenol LS 75W-90 GL-5 gear oil, where "LS" is supposed to stand for "limited slip", and for the transmission I used RAVENOL MTF-1 75W-85. I only drove the car for about 100 km or so, but nothing blew up, I didn't hear any grinding noises, and the transmission seemed to shift the same as before.
That MTF-1 looks a lot like ATF Dextron III. Boy how times have changed, back in the day one injected 75W-90 into the transmission and called it a day.
The whole job of changing the differential and transmission fluids was way easier than I thought, with the car on the lift, I was done in exactly two hours. Got to use my transmission oil hand pump which I bought at "AutoZone", back when I was a young kid still living in the U. S., several decades ago. That was a blast from the past.
The only suspicious thing was that the manual says 4.4 L, but I was at 4 L and the fluid started running out. I tried one more injection after that, but it just kept running out. Strange.
