Old 04-12-2025, 08:49 AM   #1
Marty12zl1
Drives: Chevy camaro zl1
2012 ZL1 supercharger coolant
Hi All :
I was lucky enough to recently purchase a 2012 ZL1 with 29 miles ( basically new).I was going to do some preventative maintenance on it including oil/filter and coolant . I then realized that the supercharger also has coolant . I looked for quite a while but did not see any DIY videos on the subject . I did see where people added an additional reservoir kit or stated that the car should be brought to the dealership for service.
I plan on using the car very little . A 15 mins easy drive three times per year spring/summer and fall. Wondering what peoples recommendation would be on what to do about the supercharger coolant .
Thanks you
Marty
Marty12zl1 is offline   Reply With Quote
Old 04-12-2025, 10:16 AM   #2
ZMEnow
Drives: ZL1, 2013, tri-coat-red, manual
The SC has dexcool in it just like the engine so it needs to be taken out every 5 years or it begins to congill. Bleeding without a reservoir is tricky as any air in the system will cause the pump to shutdown. You can negative pressure fill, or install a reservoir. If you want to stay stock head over to JRE, and purchase the pop bottle burpee as it looks stupid but works.
ZMEnow is offline   Reply With Quote
Old 04-12-2025, 11:41 AM   #3
Risingson05
Risingson05's Avatar
Drives: 2015 zl1 m6
I just run distilled water and water wetter
791whp 699 ft lbs torque on E30 - ported sc /heads by boost mode racing - PAT G cam /Tune
PB:10.5@135
Risingson05 is offline   Reply With Quote
Old 04-12-2025, 09:50 PM   #4
ZMEnow
So do I but then I have to drain it for winter and add antifreeze as I haven’t started my since October, maybe next week.
Old 04-26-2025, 03:30 AM   #5
Annatar
Annatar's Avatar
Drives: ZL1 six speed manual
Everything ZMEnow told you is correct; additionally, "Dexcool" contains a rust inhibitor and that's why it must be changed every five years. This goes for both engine and the supercharger.
Do not use anything else, as internal corrosion will result. If you don't use pre-mixed "Dexcool", use distilled water to dilute the "Dexcool" concentrate.
Bleeding the system is a tricky affair, but if you really want to do it yourself, here is how:
Annatar is offline   Reply With Quote
Old 08-10-2025, 05:41 PM   #6
hypoxic
Drives: '12 ZL1 CRT
Did you ever get an answer? I'm the original owner of a 2012 and I recently changed the super charger coolant. It can be done at home and it will save you a bunch of money! It does take a couple of hours. Let me know if you need some help.
hypoxic is offline   Reply With Quote
