Old 04-15-2025, 06:17 PM   #1
spyderbuddy
Battery to car bolt
Time to clean those Ground bolts in the Trunk
and time to clean those battery Terminals
Old 04-18-2025, 07:58 AM   #2
kevint
Drives: 2013 1SS
Mine is a rusted mess. I should drill it out and replace it at this point.
kevint is offline   Reply With Quote
Old 04-22-2025, 12:55 AM   #3
InFiD3ViL
InFiD3ViL's Avatar
Did that to mine a few years back, as the bolt was cross threaded and snapped. It was the cause of a slow crank issue I was dealing with for ages. I also took the opportunity to add a 2 gauge ground cable in addition to the stock cable.
Old 04-22-2025, 08:44 PM   #4
J35Y2
Drives: 2010 Chevy Camaro 2SS manual coupe
Which bolt was cross-threaded? The one tightening down the factory negative battery ground, down in the trunk well?
J35Y2 is offline   Reply With Quote
