![]() Drives: 2011 Camaro 2SS/RS Join Date: Jul 2021
Random parts combo - will it work
On a 2011 SS...
Installing... BMR TCA028 Lower Control Arms BMR ELK006 End Links BMR TR003 Toe rods Pedders XA coilovers Would a stock GM sway bar from a 2014 ZL1 fit this setup? Actually, I think it's from Z/28 (part no: 22812943). Seems to me it it bolts up to cradle it would because the LCA's are made for FE3 or FE4 and the Endlinks as well. Any issues with this setup? Too stiff or too unmatched to a stock SS front end (except the coilovers)? I can get the sway bar super cheap so thought it would be a decent upgrade from stock FE3 SS sway bar. Last edited by SS_Dave; 04-22-2025 at 10:33 AM. |
I found out it doesn't quite work. Spare tire well clearance issue.
Will Cave
Drives: 2010 Victory Red 2SS LS3 Join Date: May 2023
