Old 05-04-2025, 05:40 PM   #1
rednecks70
Drives: 2013 AGM ZL1, '70 Chevelle 454
Tire question
Had a valve stem leak at the last TNIA, didn't get to do the last session but drove it home. Local tire place (chain store) wouldn't replace the valve stem because the tire doesn't have enough tread on the outside and was obviously looking worn. I've done 4 to 5 TNIA on these tires but usually only do 1 or 2 laps of the last session because of getting low on gas. I don't think the tire looks that bad and was hoping to get a few more events on them. What do you guys think? I know someone else will repair the valve stem.
2013 ZL1, M6, AGM, CAI, 1 7/8 Kooks Headers, 10% OD Pulley, ID1050 Injectors, 575 RWHP
rednecks70 is offline   Reply With Quote
Old 05-05-2025, 10:01 AM   #2
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
In looking at that tire, I'm thinking yeah, they might be about done. You probably won't get much more out of them in looking at the one side, it's pretty well done. If you just need the stem replaced, it shouldn't matter how it is worn, a tire shop should do it anyway because you still have some life left in them. Find a different shop.
Old 05-05-2025, 02:43 PM   #3
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
They have a little life left in them, but some shops don't like to touch used tires. I don't get to drive the toys as much as I like so the track tires age out before they wear out. I saw a tool (probably on Youtube) that allowed you to put new valve stems in without breaking the bead. I was thinking about using it for a mud tire on the truck but never got around to it.
Old 05-05-2025, 03:26 PM   #4
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
Those tires are in great shape and your tire shop is on drugs.
Find another place and don't go back there.
Old 05-05-2025, 09:51 PM   #5
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Tire shop just needs to do as told now if they make you sign a waiver for it plus all you want is a leaky valve stem. An this is the for sale forum you can use the Technical Forum to get answers.
Orange Krush II
Old 05-06-2025, 11:01 AM   #6
cdb95z28
cdb95z28's Avatar
Drives: 2022 1SS 1LE A10 BCD WCT+PDR
THIS. That is a SuperCar3 and many of us track day guys have run them to the cords.
2022 1SS 1LE A10 BCD WCT+PDR2014 1SS 1LE NPP RECARO SIM-SOLD1995 Z28 M6 GSC PGM-SOLD1975 NOVA COUPE 300HP 350 TH350 FLASH RED-SOLD
"KEEP THE FAITH"-Fbodfather
cdb95z28 is online now   Reply With Quote
Old 05-09-2025, 09:34 AM   #7
rednecks70
Thanks everyone, that is what I thought but wanted to make sure. I had a mobile tire guy try to replace it but he was concerned about scratching the rim. Going to look for another shop.
