Old 05-05-2025, 04:11 PM   #1
malibupaul
Drives: 2013 Camaro 2LS
Differential noise
My 2013 Camaro 2LS had the diff replaced twice. No abuse, just failure. First the gears were replaced. When the noise continued, the dealer believed the housing was warped, so they replaced the housing, and the gears again. All was under warranty at 30K miles. Now, about 20K miles later, I think it’s still loud. I think it has always been a noisy (humming) drivetrain. I’m planning on changing the fluid. I’ll look for metal, but if finding none, anyone had this issue or found a fluid that is better to quiet this down? I found another thread where a member stated that Camaro diffs are noisy, but that was a higher end Camaro with posi. Mine has a standard LS diff.
malibupaul is offline   Reply With Quote
Old 05-05-2025, 08:49 PM   #2
SummitWhite11
SummitWhite11's Avatar
Drives: 2010 2LT/RS
Are you the original owner? Were your differential bushings replaced with aftermarket by any chance. I heard that some aftermarket bushings will cause the drive train noise. Are you running an aftermarket exhaust as well? Could it be the drone?
2010 2LT/RS
ZL1 Appearance package, Flow Master American Thunder Cat Back Exhaust w/ QUAD TIPS, K&N Typhoon CAI, Ported VMAX TB, OEM GM Brembo Brakes Package w/ Hawks Carbon Ceramic Pads, Night Owl Halo Kit (WIFI), Rear Oracle Blue LED Bowtie, Oracle Ghosted Painted Side LED Markers, Silver Sided Gills, OEM Satin Camaro Fuel Door, OEM Strut Tower Brace, Detroit Speed Engineering 1.5" Lowering Springs, Koni Orange STR.T Struts, Z28 rear LCA's, Black Magic rear 32" sway bar, 1LE front sway bar w/ DSE end links, Aluminum Blend Door, Evil Energy Catch Can.
SummitWhite11 is offline   Reply With Quote
Old 05-05-2025, 09:01 PM   #3
malibupaul
I’m the original owner. The car is total stock, 50K mikes, with the original exhaust. The diff, and any other maintenance and repairs was done by the dealer. It’s not exhaust noise. Thanks.
Old 05-06-2025, 06:46 AM   #4
larry_g
larry_g's Avatar
Drives: 2014 1SS/1LE
Worn tires or even wheel bearings can make a humming noise as well.
Sent from my Pixel 8 Pro using Tapatalk
Old 05-06-2025, 10:19 AM   #5
malibupaul
The tires are original, so they are getting fairly worn. Thanks for the feedback.
Old 09-08-2025, 04:43 PM   #6
malibupaul
I bought Valvoline Premium Full Synthetic to replace the factory fluid.
Old 09-08-2025, 08:57 PM   #7
Moto-Mojo
Fast Cars and Old Guitars
Moto-Mojo's Avatar
Drives: 2015 2SS RS (L99, baby!)
I've been hearing a low frequency, metallic grumble for quite a while. I've had MRR wheels on for 20K miles or so and wonder about the wider offset is stressing the wheel bearings? Then other days I think it's the diff. Engine RPM doesn't change it. So it's a rolling grumble. Car has 49K miles.
Moto-Mojo is offline   Reply With Quote
Old 09-09-2025, 01:36 PM   #8
malibupaul
Just changed my diff fluid. No change in noise. My neighbor agrees with Larry g that it could be tire noise when I told him they were the originals, 12 years old.
2013 2LS
Old 09-09-2025, 02:25 PM   #9
redcoats1976
it could be tire noise,mine did that once they had about 25k miles on them.
