![]() Drives: 2010 Camaro SS Join Date: Sep 2020
417 LS3 Camaro SS
Due to a cracked piston I built a 417 Scat 4340 Stroker, local machine shop did the hone and cam bearings and I stroker clearanced it and built the rest. All ARP 12 point fastners.
Ordered from CNC motorsports, everything was perfect. Scat has excellent machining and everything was bang on. Some pics for the people's! Last edited by LS3SSSuperSport; 05-07-2025 at 03:34 PM. |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2014 2SS/RS 6SP Ashen Grey Join Date: Aug 2021
Very nice, Let us know how it runs, Cam specs? Head specs ?Any other upgrades.
GM 3.91/TrueTrac OEM ZL1 Rims, 6 Piston Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, GC Aluminum DS,Stainless Works Ceramic LTH/HiFlo Cats, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace, Moroso Catch Can,SCT X4 Dynosteve,Remote Clutch reservoir,Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights
AeroForce Dual gauge/Autometer pillar mount. |
![]() ![]() Drives: 2013 Camaro 2SS AGM Join Date: Apr 2020
Very nice, you will love it! Who is doing you tuning.
2013 2SS GPI built & tuned 415, spec'd by Andrew Cammer. GPI ported intake/tb/heads, Tooley springs, CHE trunnions, Callies rotating assembly, Diamond pistons, GPI SS3 VVT, ATI 10% ud damper, Circle D 3800, Kooks ceramic coated lt's with green cats, Mishimoto rad & oil cooler, Derale trans cooler, Holley efi rails. DSS driveshaft, trutrac with 3.91's, G-Force renegades, Hendrix solid cradle bushings Bmr: poly diff bushings, Strange adjustable coilovers, sub frame connectors, ZL1 npps, controlled with a vac pump & mac boost control solenoid.
#4 | |
The mack daddy of intakes..I believe..lol Performance Design LS3 intake port matched to my heads with a 102 throttle body. Cammotion 8620- 238/254 .630 .630 TSP PRC 260 Heads 1 7/8 Long Tubes And 3.73 rear gears. |
Just a local guy on a mustang dyno. It's the only dyno I use so he has all the graphs from all the years of upgrades. It reads low but, as long as I show a gain I don't care.
I guess that ping I herd on start up should have been addressed, oh well I got a stroker kit out of it. Piston cracked at startup at work. Drove there fine and then at the end of day, when to start it and made a bang than ran rough, so I drove it home... piston was smashed it millions of pieces. Never did find any pistons when I took the headers off. |
#6 |
GPI Sales Consultant
Fun build. That intake is so intriguing - test results have looked decent - definitely needs to have the biggest TB available on it to deliver its best.
Got a question about a GPI product? Feel free to shoot me a message! |
#7 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 CGM 2SS/RS LS3 Swapped A6 Join Date: Sep 2016
I have been very interested in the Performance Design intake. But a couple things would have me nervous about running it. Mainly, the fuel rails and injectors under a cover. Not being able to see them and quickly inspect for leaks? IDK, I might be overthinking things, but that makes it awful hard to spot a leak and then *poof* - no more Camaro.
#8 |
Update took the car for a drive yesterday with BR30 breaking oil and running great!! I did have a set back, I had a leaking head gasket with the felpro gaskets shown in the pictures. So I pulled the heads and installed TFS Cometic .045 to help quench. I upped the torque on my ARP studs ro 90lbs and pressure tested it and no leaks!! I ran cometic before with no issue and should have went with them. My new clutch is also work amazing!!!!! I burned out a RXT Twin, was crap from the start. This Twin Extreme feels like stock, engages off the bottom, feels great. Trust just buy the ACT you won't be disappointed!! Part Number T2S-G05 - ACT Twin Disc Extreme Street Clutch Kit. Will be at the dyno at the end of the month, keep you posted.
#9 |
2&THEHIT
Drives: 5th Gen Camaro; 5th Gen Ram 3500 Join Date: Mar 2018
Very cool! Thanks for the updates!!
#10 |
What clamps did you use for your header wrap???
Orange Krush II
#11 |
![]() Drives: 2014 SS Camaro Join Date: Jun 2025
Hi just going over your posts , I just bought a 2014,Camaro SS with a Ls3 and 6 speed std trans., it has a hurt engine , he was not sure what happened was running good, went into a store come back out started it up made a crunching type noise stalled out, he left it at that point. I started pulling front water pump and timing cover off to check tensioner out it was fine but in the pan I could see a few pces, fished them out and found a pce of piston and piston ring. Is this somewhat of a common problem with these motors ? Thanks for your time.
#12 |
#13 | |
#14 |
Update.
Hit the dyno two weeks ago, mustang dyno so you know numbers 15% off a dyno jet...but hey it's a measuring tool so here are the gains. It's a small cam at 238 254, but still made great gains. The torque you can feel, it's so much faster, it just pulls. We should have ran it up to 7000rpm, and maybe some more timing but I can always dyno it next year. Share your thoughts. |
