Old 05-10-2025, 01:30 AM   #1
Z ya later
Drives: Z/28
Availability of brake pads and CCM rotors
Has anyone found brake pads or replacement CCM rotors for the Z/28 recently?
I am not ready to do a steel conversion yet.
I know some have been looking at the solution of bolting Corvette rotors to the Z/28 hats. If anyone has some accurate and definitive solutions, please post them up.
Conversely, if others found stuff that did not work, please post that up too.
If anyone has some OEM pieces for sale, please pm me.
Thanks.
Z ya later is offline   Reply With Quote
Old 05-10-2025, 07:48 AM   #2
Coz3z3
Drives: 2015 Z/28, 2015 1LE
I saw RacingBrake has replacement carbon ceramics for us. Front and rear
Coz3z3 is offline   Reply With Quote
Old 05-10-2025, 05:32 PM   #3
void_kp
void_kp's Avatar
Drives: Chevrolet Camaro Z28 (2015)
that's great info. how do you find which one is the right one for the z28?
2015 Red Z/28.
Seattle area
void_kp is offline   Reply With Quote
Old 05-11-2025, 10:25 AM   #4
Coz3z3
For some reason I can't find on there anymore the specs list. I saw it on there before.
Here is the fronts
https://racingbrake.com/cr32/
Rears
https://racingbrake.com/cr20/
Edit: here's that list of all camaros and the sizes
https://racingbrake.com/camaro-7/
Old 05-11-2025, 11:48 AM   #5
Coz3z3
They also list our "iron conversion" size as the same as the 6th gen ZL1 1LE. I'd be curious if those would somehow fit?
Old 05-11-2025, 07:16 PM   #6
craZed
craZed's Avatar
Drives: Z/28 15 AGM
Brembo OE Replacement Pads for Z/28
You can also check bremboparts.com (Brembo N.V.) and brembostore.com (Brembo North America) for OE replacement ceramic pads (Brembo Prime Ceramic).
Bremboparts.com lists the P37018N as a front replacement with acoustic replacement indicator and P10096N with electronic replacement indicator. Brembo technical data sheet for P10096N says its an OE replacement for GM Part #22990624 (Z28 front pad). The P85116N and P85110N are shown as OE replacements for the GM Part# 22990625 (rear Z28 pads) on bremboparts.com. Only the P85116N is shown as an OE replacement on brembostore.com. Both the P85116N and P85110N are shown as "Prepared for Wear Indicator".
Brembo Prime Ceramic pads are available from a variety of US-based sources including Amazon (generally third-party vendors), TireRack, Summit, O'Reilly, and others.
craZed is offline   Reply With Quote
Old 05-11-2025, 09:18 PM   #7
Gouki
Drives: 2014 Z/28
https://racingbrake.com/pd1165-21/
https://racingbrake.com/pd1395-21/
Rear and front pads, no wear sensors but the Brembo part numbers are the same.
Gouki is offline   Reply With Quote
Old 05-11-2025, 09:25 PM   #8
Gouki
Drives: 2014 Z/28
I found the aforementioned by searching the Brembo part number on the pad.
Front
07.9408.51
Rear
0797062200
I have since bought the rears and they were a perfect match.
Old 05-11-2025, 11:23 PM   #9
Z ya later
Drives: Z/28
There is some great info here.
Thanks, much appreciated!
