Old 05-10-2025, 05:50 PM   #1
jblaiseSS
2012 SS/RS M6
jblaiseSS's Avatar
Drives: 2012 Chevrolet Camaro SS/RS manual
GPI SS4 NFC Camshaft Project
I've been piecing together my parts list for this camshaft install. So far I've got the GPI SS4 NFC camshaft, Ported intake manifold from GPI, BTR valve spring kit, proper pushrods, CHE trunnion kit, and sprocket/bolts to accompany the install. Other upgrades include CAI cold air intake, elite engineering catch can, and kooks long tubes. What, if anything, is needed or recommended before I bring all of this to the shop for install and tune? (I am staying NA so please don't say supercharger)
jblaiseSS is offline   Reply With Quote
Old 05-11-2025, 04:23 AM   #2
morepowerjoe
morepowerjoe's Avatar
Drives: 2012 Chevrolet Camaro l99
If I was you I would strongly recommend at least the gm performance racing lifters and if you do the lifters then I would also recommend some cometic .040 head gaskets to get your compression up a little more if your going to stay N/A, your engine will thank you for it. And a couple more things, arp head bolts or studs, an arp balancer bolt, and all the gaskets if you want to get good ones because the shop will probably cheap out on them to save money. Also make sure your pushrods are hardened.
DSS Pistons, Eagle ESP L19 Rods, ARP Head and Main Studs, TSP PRC CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Racing Lifters, CHE Trunnions, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP Longtubes, ZL1 Fuel Pump, Mishimoto Radiator and Oil Cooler, 3600 Circle D Converter, Tru Cool 40k Tranny Cooler, Fluid Dynamics Balancer, EBC 3GD Rotors with EBC Bluestuff NDX Pads, Bilstein B6 Shocks / Struts with Eibach ZL1 Drop Springs
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817
morepowerjoe is offline   Reply With Quote
Old 05-11-2025, 09:02 AM   #3
jblaiseSS
2012 SS/RS M6
jblaiseSS's Avatar
Engine only has 23K miles....should've added that earlier. Not going to race or track this car. Street application only.
Old 05-13-2025, 06:58 AM   #4
joshnmn
2&THEHIT
joshnmn's Avatar
Drives: 5th Gen Camaro; 5th Gen Ram 3500
That really doesn’t matter.
Agree with Joe ^^
joshnmn is offline   Reply With Quote
Old 05-13-2025, 07:47 AM   #5
acammer
GPI Sales Consultant
acammer's Avatar
Drives: 2011 Camaro 2SS SGM
You cannot add an .040" gasket with that combination unless you also flycut - the SS4 NFC is at minimum acceptable piston to valve clearance with stock internals and unmilled heads/deck.
Got a question about a GPI product? Feel free to shoot me a message!
acammer is offline   Reply With Quote
Old 05-13-2025, 07:52 AM   #6
acammer
acammer's Avatar
Even though the car is low miles, an aftermarket/upgraded oil pump is always a worthwhile consideration on LS3 cars - as those pumps have a bit of a history with sticking the regulator and leaving you suddenly with no oil pressure. HD timing chain and LS2 style damper are also good upgraded to make while it's apart.
Lifters are the most common failure you see on LS engines, stock or modified, and should be on the list for any car that's going to see more than .600" lift, more than 400lbs of open pressure, or over 7000rpm. Your combination checks all three boxes, and so a Chevrolet Performance - Racing (aka Caddy) lifter would be the minimum acceptable option IMO.
ARP hardware is always a nice move, if it ever has to come back apart you'll be glad you did it. And underdrive pulley is a common upgrade to be done while doing a cam, since the balancer is already coming off.
Old 05-13-2025, 08:03 AM   #7
morepowerjoe
Yeah thanks Andrew I forgot about that.
Old 05-13-2025, 10:34 PM   #8
Bo White
Bo White's Avatar
I ran stock lifters for a while on mine until I swapped heads. I then put new trays and Caddy lifters in
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter, stage 4 cam and Wilkes 11° 65cc heads
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
Old 05-17-2025, 11:13 AM   #9
VRCamaroSS
Drives: '10 Camaro 2SS/RS
High pressure or high volume oil pump.
VRCamaroSS is offline   Reply With Quote
Old 05-19-2025, 08:29 AM   #10
acammer
acammer's Avatar
Yes - meaning both. The Melling 10296 is our go-to pump for 5th gen builds that aren't using VVT. Standard (installed) spring is fine, no sense adding the COPO spring unless you cap the relief in the pan. I've got an oil pump guide on the site that might be useful information if you want to read more.
https://gwatneyperformance.com/melli...-guide-for-ls/
Old 05-19-2025, 11:37 AM   #11
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
I've been running the 10295 in mine for about 7 years now and 34k miles. To date it keeps really good oil pressure throughout the entire rpm range, from idle to WOT.. And everywhere in between..
Old 05-19-2025, 12:14 PM   #12
VRCamaroSS
I am sticking to NA but still deciding on a BTR stage 2 or stage 3 cam. I am deleting DOD/VVT. But also think my stock oil cooler is leaking and will either delete or add my own.
Old 05-19-2025, 12:57 PM   #13
Trawz
Trawz's Avatar
Drives: 2013 Camaro 1LE
Put in a Melling 10296 pump at Acammer's recommendation last summer.
Also did the removable secondary crossmember brackets, Improved racing oil pan baffles, oil cooler delete kit, and oil pressure relief valve delete.
It's been fantastic. Was hot idling at around 20psi before the swap, not hot idles at 38psi and shoots all the way to 70psi at high RPMs.
2013 1SS/1LE
Corsa Extreme cat-back, Speed Engineering LT Headers with black ceramic coating, C7 Z06 Front Brake Upgrade, Custom Mishimoto Oil Cooler, BMR Tunnel Brace, Custom Dual Mishimoto Oil Catch Cans, MSD Plug Wires, Mishimoto Radiator and Hoses, Melling High Volume/High Flow Oil Pump, Improved Racing Oil Pan Baffle Kit, Improved Racing Oil Pressure Bypass Delete, Improved Racing Oil Pick-up Tube Clamp.
Trawz is offline   Reply With Quote
Old 05-19-2025, 02:33 PM   #14
acammer
acammer's Avatar
For reference, the 10296 in my SBE LS3 with COPO spring and the pan relief capped makes 90+psi from 4500-7800rpm. It certainly borders on excessive.
