Old 05-11-2025, 08:31 PM   #1
SS_Dave
SS_Dave's Avatar
Drives: 2011 Camaro 2SS/RS
coilover install help
Anyone in the DFW area that has done Pedders coilovers wanna show me how the heck to do these?
Maybe I'm being obtuse or paranoid about this. But the instructions they came with are minimal at best. I've found older more verbose instructions, but getting a tad confused and also don't knowif there's been design changes since those writeups. Just finding myself really unsure and want to be right before I put it all back together. Especially since I have the whole cradle out for other components as well.
I think I need a solid video for dummies on these.
SS_Dave is online now   Reply With Quote
Old 05-12-2025, 11:15 AM   #2
SkunkJunk420
SkunkJunk420's Avatar
Drives: camaros
https://youtu.be/DTF6FOPFxPk?si=HukP4jAHfjws_A_A
https://youtu.be/1ulr6abZ13Y?si=IW7HhGeLy1VtW0eP
I used these videos to help put my pedders coils on. Im not a mechanic but this was an easy install. You dont have to cut the trunk like in the video, you just drill a hole on the rear bracket. Good luck, you got this!
SkunkJunk420 is offline   Reply With Quote
Old 05-12-2025, 11:36 AM   #3
SS_Dave
SS_Dave's Avatar
Saw his front one, but kind of ignored it since BC. But it looks like they're about the same. And not hard. Will check out the back as well.
Old 05-12-2025, 11:49 AM   #4
SS_Dave
SS_Dave's Avatar
Never saw him calculating height adjustment, though. I'm wondering if they come pre-set to stock height or what? And can you measure and set them to be effectively 1.25" or whatever you want lower before even installing? Or do you have to install, re-clock, and then jack up and set them?
Old 05-12-2025, 07:31 PM   #5
MSgt O
MSgt O's Avatar
Drives: 2012 Camaro 2SS/RS Vert LS3/M6
usually you set final ride height/alignment once installed unless there are markings on the strut for ride height to "pre-set" them before install, but I have never seen that
MSgt O is offline   Reply With Quote
Old 05-12-2025, 07:44 PM   #6
SS_Dave
SS_Dave's Avatar
I found no markings, but they say they’re defaulted between 1 to 1.5. So I just measured and made sure they were locked in to same height. At least that’s the way the rear is since you have to pull them apart first. So I’ve got them built and we’ll see after I get the cradle in how far off I am from what I want.
Old 05-13-2025, 11:41 AM   #7
MSgt O
MSgt O's Avatar
Good Luck! I have a a set of Ridetech coilovers coming, so Ill be doing this exact job in a week or so...excited to see the car once theyre installed!
