![]() Drives: 2011 Camaro SS LS3 Join Date: Oct 2020
Lifter tick? Guidance from here
Hello everyone. Been a while.
Cars been running well until recently and now I’m getting what I am fairly certain is lifter failure. I’ve pulled valve covers, all rockers are tight and nothing was collapsed. I am receiving no check engine light nor rough running. Noticeable tick that accelerates with engine RPM. I am going to put the covers back on and test the exhaust flange to see if the exhaust is leaking again. Here is a video of the noise. Any confirmation on my worried would be appreciated. https://youtube.com/shorts/fjm-Vp47x...naDtyCKc2UphS_ Some further questions: how can I go about verifying it is the lifter before I pull everything apart? Ways to test if this might be pushrod or trunnion related?
2011 2SS/RS 6M: Hurst Short Throw Equipment, Speed Engineering Headers, Spectre CAI, BTR Stage 3 Camshaft 229/244 .630"/.615" 113+4, Chromoly Pushrods, .660" Springs with steel retainers.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: ABM #93 Join Date: Oct 2018
Exhaust manifold leak is where I’d start given the rockers are all tight still.
ABM #2399 2SS/RS:SOLD
ABM #93 2SS/RS Black Rally stripes, Titanium Interior 4,000 miles: GM GFX side skirts and diffuser waiting on paint, GM dovetail, GM heritage, RPI ZL1 style splitter. ‘87 IROC-Z Iroc blue. all original unmolested with 50K miles. |
Is that the thought or is it a wild guess? Not to be a jerk. I just don’t really know where to go from here and am frazzled over the idea of having to pull heads
Here is a YouTube video of the valve lash. The assumption is this play is not normal but it is also not off the lobe of the cam for all the cylinders. https://youtube.com/shorts/pQV5UO8fV...REgVlImDbix-XV
Thanks in advance again everyone
Some Side to side play isn’t a huge deal. Up and down play is what you are looking for. In order to check it correctly you need to bring each cylinder to top dead center compression stroke when both valves are relaxed. If there is significant play at that point you’ve likely got issues unless the rockers weren’t tightened down correctly. In the first video I don’t really hear a tick that is consistent with rpms it’s more at random but it very well could be that the audio didn’t pick up quite right on your phone. It sounds like you might be cammed, if so Did you do a trunnion upgrade? If the trunnions have failed it should be obvious that the rockers have vertical play at the pivots. If it’s a lifter the rocker will not have play, it will be in the pushrod assuming the rocker is torqued correctly.
I used to build engines professionally.
#6 |
Aqua Blue,
My signature is up to date with the parts on my car. The trunnion upgrade was not done but I do have a set of BTR trunnions I plan on throwing in the car once this is set and done. I also have stock LS3 lifters at ~90k miles. I have heard of the lifters failing with a "large" cam like the BTR stage 3 but this seems quite random as I keep oil clean and fresh and coincidentally happened after it had been garage kept for 2 months. The noise does indeed increase with RPM but still is not quite as rhythmic as what I would assume a lifter failure would sound like (I am a college kid who just happens to work on his own cars.) Here is my plan so far, any advice to this would help a lot: Manually turn engine and inspect rockers for play: If nothing turns up, remove rockers and inspect trunnions and push rods: Still nothing, then button up and spray dawn soap mixture on exhaust and inspect for bubbles for leak. Nothing else turns up, will have to remove heads and inspect myself or take to shop to have work done.
#7 |
waiting at the tree
Drives: SIM 2010 2SS/RS A6 Join Date: Apr 2013
Mine has been ticking on start up for a while.
I still have great oil pressure and just let it warm up for a couple of minutes to get the oil flowing. It seems to settle down after that. Oil always looks clean with no sparkles.
2010 2SS/RS A6 Just a few bolt-ons and appearance doo dads
#8 |
GPI Sales Consultant
It sounds like a lifter going away in the clip of it running - that chirp can be the lifter wheel sticking and sliding on the cam. It wouldn't be uncommon at all for that to happen, as it has been known to occur even with a stock valve-train. With the aftermarket cam you've added more spring pressure, more lift, more aggressive lobes, and more RPM - the lifter, now well into it's life at 90k miles, doesn't like any of that! So, it would not be a surprise to me that you've got one (or more) going away.
The side to side play in the second video is totally normal - you want to look for lash in the direction of the rockers travel when running, and you'd need to have each one you're checking be on the base circle of the cam lobe to get a meaningful idea if there is in-fact any abnormal lash. You're next steps all sound right, definitely rule out items via the path of least resistance, but that little metallic chirp is a pretty strong indicator to me. Let us know what you find.
Got a question about a GPI product? Feel free to shoot me a message! |
#9 |
![]() ![]() ![]() ![]() Drives: 2010 2SS/RS A6 Join Date: May 2019
#10 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 CGM 2SS/RS LS3 Swapped A6 Join Date: Sep 2016
I am also hearing something. Not the usual LS lifter tick. Andrew (acammer) mentioned it sounding like a chirp. To me it does, but barely, like its the very start of lifter or lifter wheel failure. If you listen carefully you can hear a rhythmic metallic clanging noise that is not in sync audibly with the typical valvetrain noise.
Best of luck man. I hope you get to the bottom of this and that you caught it early.
#11 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: SUMMIT WHITE 2SS/RS CAMARO Join Date: Feb 2008
a thing from my early '10 SS L99, but I've changed my oil 20 times in 15 years and 73,000 miles. No sparkles, I hope that was a joke.
#12 |
I see what you are saying and agree clean oil is very important, but your car is stock his is cammed. That’s not a straight up comparison at all.
#13 |
But even more reason to keep your oil clean.
#14 |
waiting at the tree
I change my oil twice a year April and November.
