Old 05-19-2025, 05:41 PM   #1
FASTFATBOY
Drives: 2013 ZL1
Did the 1LE come with brake cooling ducts?
My ZL1 has ducts, there are spots for them on my 1LE and they are not there.
Did someone remove them?
2015 1SS 1LE, Magnuson 2300 Heartbeat and headers. 550rwhp STD, 535 SAE.
FASTFATBOY is offline   Reply With Quote
Old 05-19-2025, 07:53 PM   #2
CamaroDreams76
Tri-County Camaro SWFL
CamaroDreams76's Avatar
Drives: 2013 IOM 2SS/RS/1LE
No. 1LEs did not come with brake ducts. They do have the ZL1 backing plate/dust covers for the brakes. Also they have the standard SS brakes just red calipers.
It's quite possible someone did have brake ducts on the car and removed them. I believe the 14/15s, you could easily use the Z/28 brake ducts. 13s you have to rig up your own. Can search "quantum cooling brakes" for that write up.
Old 05-19-2025, 08:16 PM   #3
FASTFATBOY
Drives: 2013 ZL1
There are rectangle holes on both sides just to the inside of the fender liners is why I ask.
Pretty sure my ZL1 has ducts in those holes.
Old 05-20-2025, 03:50 AM   #4
KillboyPowerhead
Drives: 2015 Z/22
The V6 has those holes/provisions for ducts too, but no ducts.
KillboyPowerhead is offline   Reply With Quote
