Old 05-19-2025, 10:40 PM   #1
dma05
dma05's Avatar
Drives: 2011 Camaro 2SS/RS
Carbon Fiber Driveshaft EXPLODED!!
Has anyone had this happen. There is less than 5k miles on this driveshaft. I was shifting from 1st into 2nd and BOOM! it exploded.
This is from The Driveshaft Shop. I’m calling them tomorrow, but since it was bought in 2022, I doubt they will help out. This car only goes out once every 4-6 weeks, so it doesn’t get used much. This unit was $1,800 so I would like to think it would hold up much longer than it did.
Allen
2011 Camaro 2SS/RS
dma05 is offline   Reply With Quote
Old 05-20-2025, 10:51 AM   #2
NoDakZ/28
NoDakZ/28's Avatar
Drives: 2014 Z/28 CTF
Man, I hope they help you out. After I purchased their 1200hp axles a few years ago that ended up needing a rebuild, the gave me the run around on a rma for weeks to where I just gave up. Maybe its gotten better but their service side was awful, hopefully they are willing to help you out since those are spendy units that should be pretty indestructible under said rated hp. Good luck.
2014 1LE - Sold
2014 Z/28 #99008 CTF SIM
NoDakZ/28 is offline   Reply With Quote
Old 05-20-2025, 03:07 PM   #3
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Wow! That bites. I sure hope they help you out, being the shaft was so expensive. Good luck bro.
Old 05-20-2025, 06:45 PM   #4
dma05
dma05's Avatar
They called me today and had me send pictures to see what they can do. Waiting to hear back.
Allen
2011 Camaro 2SS/RS
Old 05-20-2025, 07:07 PM   #5
0stones0
It don’t come easy.
0stones0's Avatar
Drives: 2010 2SS RS M6
Companies that give you the run around bank on you giving up. As much of a bitch as it is, stay in the fight. Let them know no you’re not going away.
0stones0 is offline   Reply With Quote
Old 05-21-2025, 07:44 AM   #6
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
DSS had historically done pretty good by customers even after warranty expires. Hope they fix your stuff.
Old 05-21-2025, 11:17 AM   #7
acammer
GPI Sales Consultant
acammer's Avatar
Drives: 2011 Camaro 2SS SGM
Wow - very interesting. If you come with a root cause for the failure I'd love to know. I would like a CF shaft for my car, but I have worries about this very thing.
Got a question about a GPI product? Feel free to shoot me a message!
acammer is offline   Reply With Quote
Old 05-22-2025, 06:55 PM   #8
dma05
dma05's Avatar
Their support contacted me and they want better pictures. They won’t replace it, but said they will examine the damage to see how much it will be to repair it. Depending on the price, I may buy a new QA1 or Gulf Coast driveshaft. Driveshaft shop hasn’t made me happy at all in the past. I went through 2 aluminum ones that had such bad vibrations and now their carbon fiber one.
Depending on their “repair” cost, it might be better to switch companies. Next week I will uninstall it and post some updated pictures.
Allen
2011 Camaro 2SS/RS
Old 05-23-2025, 12:28 AM   #9
Jeff_SS
"Cam Only"
Jeff_SS's Avatar
Drives: 2013 Camaro SS
Gulf Coast 100%. Top notch customer service.
DSS has taken care of me before, but normally it involves multiple calls and multiple weeks waiting etc.
2013 AGM Camaro 2SS/RS M6 | LSA Blower, 2.5" pulley, 10% lower, FIC1000's, Fore Innovations Twin Pump fuel system w/ Flex Fuel, CMS Custom Grind Cam, Kooks 1 7/8" headers w/ catless off-road pipes, NPP Exhaust, 3.91's, JLT ZL1 Intake, Prospeed Heat Exchanger, Monster S Series Triple Disc Clutch | Pfadt Suspension, 1LE Sway Bars | DSS 1000hp axles | Mickey Thompson ET Street R 305/45/18 |
Tuned by Ryne @ CMS E85: 734rwhp/674rwtq
Jeff_SS is offline   Reply With Quote
Old 05-23-2025, 09:43 AM   #10
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Repair it??? I don't think so with that damage. Once CF like that is damaged, a repair of it I think would only lead to another future compromise of the shaft. From what I've read about a CF piece of equipment, it can't be repaired and remain structurely sound, it needs to be replaced.
Old 05-24-2025, 02:37 PM   #11
JMI
JMI's Avatar
Drives: Red Jewel Camaro SS
The exhaust heat might have made it brittle.
I have been running one for a few years now with no issues.My exhaust is heat wrap around the area of the driveshaft.
BTR LSX388,AGP Twin Turbo.6L90,GM 9.9" Diff.Fore Innovations Level 4 fuel system.Great fuel economy !!!! 1xxx RWHP
JMI is offline   Reply With Quote
Old 05-25-2025, 10:29 PM   #12
FasNuf
FasNuf's Avatar
Drives: 2014 Camaro ZL1
They probably just reuse the aluminum ends.
Heat plays havoc on some adhesives but I'd be curious if Park brake cables were rubbing..
FasNuf is offline   Reply With Quote
Old 12-31-2025, 10:55 PM   #13
dma05
dma05's Avatar
UPDATE!
It’s been some time now since my DSS exploded and I finally bought a new Gulf Coast carbon fiber one to put on the car. I installed it this weekend and uninstalled the DSS one. It looks like the DSS failed right by the coupler. It was so twisted that I couldn’t take the bolts out!! Definitely a weak point. I’m done with DSS.
The new Gulf Coast is installed and working great! I also decided to wrap the X Pipe exhaust so that heat won’t be an issue.
I wanted to make sure to give an update on this post.
Allen
2011 Camaro 2SS/RS
Old 01-01-2026, 11:15 AM   #14
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Oh wow, that's an odd place for it to fail! But I'm glad you got it off and have a new shaft installed and it is going well. I hope it does you right for a long time, so you can enjoy your beast! Thanks for getting back with us.. Happy New Year!!
