Old 05-21-2025, 05:04 PM   #1
FASTFATBOY
Drives: 2013 ZL1
Putting ZL1 brake cooling ducts on a 1LE
The holes are there.
Has anyone tried it?
2015 1SS 1LE, Magnuson 2300 Heartbeat and headers. 550rwhp STD, 535 SAE.
FASTFATBOY is offline   Reply With Quote
Old 05-21-2025, 05:28 PM   #2
bsn
Drives: 2013 ZL1
Finding the ducts is the hard part.
bsn is offline   Reply With Quote
Old 05-21-2025, 06:08 PM   #3
FASTFATBOY
Drives: 2013 ZL1
Wrecked ZL1's, Hawks Motorsports has some as does a few other places.
Old 05-22-2025, 10:40 AM   #4
FASTFATBOY
Drives: 2013 ZL1
Looks like you could do it, you would have to cut here and fab to match the hole.
Old 05-29-2025, 11:27 PM   #5
Trawz
Trawz's Avatar
Drives: 2013 Camaro 1LE
I made my own with parts from Summit Racing.
Cut holes to accommodate the ducts in the plastic air deflector and ran tubing into the wheel wells.
Its not the perfect system but does fill the wheel well with cool air and seems to work well! I just need some brake cooling bracket made to run the tubing straight to the back of the rotor.
2013 1SS/1LE
Corsa Extreme cat-back, Speed Engineering LT Headers with black ceramic coating, C7 Z06 Front Brake Upgrade, Custom Mishimoto Oil Cooler, BMR Tunnel Brace, Custom Dual Mishimoto Oil Catch Cans, MSD Plug Wires, Mishimoto Radiator and Hoses, Melling High Volume/High Flow Oil Pump, Improved Racing Oil Pan Baffle Kit, Improved Racing Oil Pressure Bypass Delete, Improved Racing Oil Pick-up Tube Clamp.
Trawz is offline   Reply With Quote
Old 06-06-2025, 09:58 AM   #6
Pdurio
Drives: 2015 SS 1LE
I am working on bringing back a 3d printied option for the Z/28 brake duct kit.
Pdurio is offline   Reply With Quote
Old 06-06-2025, 10:04 AM   #7
FASTFATBOY
Drives: 2013 ZL1
Awesome.
I got my brakes a little too hot at Tail of the Dragon, has DOT4 fluid and factory pads but I could feel them getting hot.
Never had that happen in the ZL1 up there with the ducts.
Old 06-06-2025, 10:09 AM   #8
FASTFATBOY
Drives: 2013 ZL1
This is awesome, I did something similar on my 4th gen. I ran the air through the frame rail.
