Old 06-06-2025, 06:28 AM   #1
Franfd60
Drives: 2012 convertible camaro 2lt 45th
2012 camaro convertible
I have a 2012 Camaro convertible 3.6 LT. My water management bag needs to be replaced and the part shows discontinued. Does any one know of a after market place that makes them?
The original part number was 22847835. they change it to this new part number 23124571. I do not want to get rid of the car because of this. Mine car is a 45th anniversary edition.
Franfd60 is offline   Reply With Quote
Old 06-07-2025, 02:02 AM   #2
J35Y2
Drives: 2010 Chevy Camaro 2SS manual coupe
Water management bag...? What's that again exactly?
J35Y2 is offline   Reply With Quote
Old 06-07-2025, 06:36 AM   #3
tartagliazl1
tartagliazl1's Avatar
Drives: 2013 zl1 vert
nobody makes them. you'll have to patch the hole. Or try to find a good one at a yard. good luck.
22% lower/ 2.5 upper/ 2” headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 1300/ dsx aux kit/ 103mm throttle body/ big gulp 5” intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2” lid spacer/ cnc,milled ported heads/ brick mod/BMR toe and trailing arms/ 781hp 748 tq SAE @17.3lb on a loaded dyno.
tartagliazl1 is offline   Reply With Quote
Old 06-07-2025, 04:13 PM   #4
MSgt O
MSgt O's Avatar
Drives: 2012 Camaro 2SS/RS Vert LS3/M6
Unfortunately, this^^^
MSgt O is offline   Reply With Quote
Old 06-08-2025, 07:57 AM   #5
SummitWhite11
SummitWhite11's Avatar
Drives: 2010 2LT/RS
Never heard this term before. What is a water management bag??
2010 2LT/RS
ZL1 Appearance package, Flow Master American Thunder Cat Back Exhaust w/ QUAD TIPS, K&N Typhoon CAI, Ported VMAX TB, OEM GM Brembo Brakes Package w/ Hawks Carbon Ceramic Pads, Night Owl Halo Kit (WIFI), Rear Oracle Blue LED Bowtie, Oracle Ghosted Painted Side LED Markers, Silver Sided Gills, OEM Satin Camaro Fuel Door, OEM Strut Tower Brace, Detroit Speed Engineering 1.5" Lowering Springs, Koni Orange STR.T Struts, Z28 rear LCA's, Black Magic rear 32" sway bar, 1LE front sway bar w/ DSE end links, Aluminum Blend Door, Evil Energy Catch Can.
SummitWhite11 is offline   Reply With Quote
Old 06-08-2025, 09:24 AM   #6
MSgt O
MSgt O's Avatar
its a rubberized "cell" that is under the top and catches/drains water. https://www.camaro5.com/forums/showthread.php?t=235016
Old 06-08-2025, 09:56 AM   #7
SummitWhite11
Drives: 2010 2LT/RS
Dang! And at first I thought it was a medical term ha!
2010 2LT/RS
