Old 06-07-2025, 12:02 PM   #1
102SS
waiting at the tree
102SS's Avatar
Drives: SIM 2010 2SS/RS A6
Solved Driveability Issue Codes 301,556,557 Long Read
All the above and intermittent stabilatrak lights.
Long story short code P0556 so I replace the brake booster sensor and grommet.
Well I now get P0556 and P0557 and stabilatrak the brakes work fine
Then I get the flashing check engine light and its a misfire coil 301
Change coil with Cylinder 3 and clear codes then I get misfire cylinder 1 after it goes into closed loop plus it surges and lopes.
Change plugs and wires still fubarred
Light bulb goes on and I buy a new MAF and O2's figuring it is unmetered air or contaminated O2's even though I was not getting those codes.
Nope still got the issue and now it is down shifting hard when I brake
Clean body grounds new battery last year and charging good with great voltage.
Still got the issue
I swap my ECM with one I bought online and it says the crank position senor not aligned or something and the car wouldn't crank but the codes I had previously show up
This thing is killing me
Time for a pro
He spends some time comes back and shows me a sheet of codes...no shit Einstein that is why I brought it to you
He says it is probably the ECM which is why I handed him that in the first place and explained everything right up front.
He does a compression test on bank 1 and they all come back good so its not the DOD/AFM(whew)
Clears the codes goes for a short drive and declares it fixed with the new ECM
He only charge me one hour of labour
Half way home yesterday 301 and 557 are back along with the stabilatrak lights
Ok now I need to put on big boy pants and get to the bottom of this on this wonderful Saturday morning.
After a a good nights sleep and 2 cups of coffee the light bulb comes on again
I am getting a match and burning it to the ground
No that is not the way I do things
Took it for a drive got it in closed loop
Spray some TB cleaner on the booster grommet and all around the intake ok everything is fine WTF
The match and gas are moving back to the front of my mind
But wait there is a about a foot of fuel line from the nipple on the CAI to the PCV...could it be?
Yup it had a crack in it so I duck taped it up RED Green style and cleared the codes and drove to the parts store and guess what?
PROBLEM SOLVED!!! NO CODES !!
So I bought a foot of 3/8 line and installed it.
The car runs like a raped ape again and $4.00 of 3/8 fuel line fixed it
I just got back from an hour drive up the Niagara River Parkway and I am so happy and relieved
2010 2SS/RS A6 Just a few bolt-ons and appearance doo dads
102SS is offline   Reply With Quote
Old 06-08-2025, 07:14 PM   #2
Joe.G
Joe.G's Avatar
Drives: 2014 2SS/RS 6SP Ashen Grey
Glad you got it fixed, i would tell the " Pro ".
GM 3.91/TrueTrac OEM ZL1 Rims, 6 Piston Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, GC Aluminum DS,Stainless Works Ceramic LTH/HiFlo Cats, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace, Moroso Catch Can,SCT X4 Dynosteve,Remote Clutch reservoir,Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights
AeroForce Dual gauge/Autometer pillar mount.
Joe.G is offline   Reply With Quote
Old 06-09-2025, 08:09 AM   #3
102SS
waiting at the tree
102SS's Avatar
Thanks but no I will not rub it in,my neighbor admired my perseverance and had the same thought
I don't want want to gloat or bring on bad karma
I go there regularly for oil changes,tires ect.
He was sure it was electrical or ECM and that was what I was thinking too.
But the the problem seemed to worsen in closed loop so that changed my way of looking at it.
Old 06-09-2025, 08:33 AM   #4
Joe.G
Joe.G's Avatar
Don't need to make it negative, but it surely could help the next person that has a similar issue, if I was your mechanic I'd want to know what fixed it and possibly save my next customer a lot of time money and headaches plus maybe keep from getting a negative review for something that turned out to be a cheap easy fix.
Old 06-09-2025, 01:37 PM   #5
102SS
waiting at the tree
102SS's Avatar
Your right and I was thinking about bringing it up the next time I am there.
That is why I posted this thread in case someone else has a similar issue.
