Old 06-12-2025, 07:35 PM   #1
sbelyo
Drives: n/a
Replace water pump or gaskets?
After smelling coolant for a few months and unable to spot where it was coming from I saw it at a car show when I popped the hood last week. I'd been topping off the coolant until I found it.
When standing in front of the engine it appears to be leaking from the right port in between the block and pump.
Should I replace the whole thing or just try the gaskets? The car does not run hot. 175 in the 95 degree FL heat with airflow and a 160 degree stat with a hole drilled in it
sbelyo is offline   Reply With Quote
Old 06-12-2025, 08:25 PM   #2
SS_Dave
SS_Dave's Avatar
Drives: 2011 Camaro 2SS/RS
If I'm going to trouble to take it off, I'm putting on a new one. They're not that expensive. And I might even consider new hoses as well just for good measure.
SS_Dave is offline   Reply With Quote
Old 06-12-2025, 08:55 PM   #3
sbelyo
Drives: n/a
Good point! I was thinking that myself just wanted to make sure.
Old 06-12-2025, 09:09 PM   #4
Sleper
Drives: 2015 2lt rs
agree 100%
Sleper is offline   Reply With Quote
Old 06-13-2025, 12:20 PM   #5
bsn
Drives: 2013 ZL1
Chances are its leaking from the weep hole which means the pump seal is starting to fail.
bsn is offline   Reply With Quote
Old 06-14-2025, 08:01 AM   #6
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Totally agree here..
