Old 06-17-2025, 04:32 PM   #1
drummerX
Drives: Chevy Camaro
2011 V6 Crankshaft removal
Hello. Some of the rod bearings seem to be "stuck" on the crankshaft. I recovered 9 out of 12 so far. It's hard to tell if the other 3 are still on there somewhere, plus, I'd like to have the crank examined to see if it's still ok to use. How does 1 remove the crank? Pistons are already out. Main caps are unbolted, but not moving. Checked forums and Youtube, but couldn't find info on this particular procedure. Thanks in advance!
drummerX is offline   Reply With Quote
Old 06-18-2025, 08:26 AM   #2
gtstorey
Brute force.
Old 06-19-2025, 04:58 PM   #3
drummerX
2011 Camaro v6 Crankshaft
Timing cover is off. Oil pump is unbolted except the torx. Do i need to pull it all the way off? Timing gear is still there as well. Do I need to use a puller to get that off in order to drop the crankshaft? Also---4 of 6 cylinder bores have 1/3 left of the bore still there on the bottom of the block. Normal? Purpose?
3.6l, crankshaft, llt
