Old 06-25-2025, 09:45 AM   #1
2012CamaroSs45
Drives: Chevy Camaro
THROTTLE BODY UPGRADE NEED SUGGESTIONS
Was wondering if anybody out there with a whipple set up has upgraded their throttle body? I contacted whipple and they said they suggest to look into nick williams or Katech.. was wondering if anybody has any positive experiences with these or any other throttle bodies? I’m looking to get a 102mm/103mm whichever one I find and was also looking to see if it will be a direct bolt on to the 2.9L whipple or what I would need if it’s not
2012CamaroSs45 is offline   Reply With Quote
Old 06-25-2025, 12:56 PM   #2
larry_g
larry_g's Avatar
Drives: 2014 1SS/1LE
Nick Williams makes a 103 for boosted applications, just make sure you are buying a legit one from a reputable source. Whipple makes an adapter and gaskets for the larger throttle body, you can order directly from them.
What kind of horsepower are you aiming for? My ported stock throttle body didn't become a limiting factor until I was around 760 at the wheels.
Keep in mind, you will also need a fresh tune, so it's always a good time to do any other mods you are considering.
Sent from my Pixel 8 Pro using Tapatalk
Old 06-26-2025, 10:45 PM   #3
2012CamaroSs45
Ok cool thanks for the info. And I’m aiming for about 800. I got just about everything done except for a big cam which I plan on getting done with a couple supporting mods so I figure why not upgrade the TB with a nice big cai while I’m at it lol
Old 06-28-2025, 02:40 PM   #4
pyroguy
Started#gottalovethatblue
pyroguy's Avatar
Drives: ABM #832
Both Nick Williams and Katech are reputable places to get throttle bodies from. Reach out to Bo White here if he doesn't chime in as many of us have his ported throttle bodies on our Camaros. He can definitely point you in the right direction without a shadow of a doubt.
Check out my build thread
Old 06-28-2025, 02:55 PM   #5
CamaroDreams76
Tri-County Camaro SWFL
CamaroDreams76's Avatar
Drives: 2013 IOM 2SS/RS/1LE
My friend has a built ZL1 with a 2650 and hes gone through two NW102s. The electronics went bad in both. Ended up going with the new Kong 112. Id pick Katech over NW.
