Old 06-26-2025, 07:53 AM   #1
RGC1
Drives: 2014 SS Camaro
Will this clutch work ?
Just wondering if anybody can tell me will the dual disc clutch from GM for ls/lsa. Work in my 2014 ls3 ?
Also would it use the same throw out bearing ?
Or should l just go centreforce or McLeod ?
So far I’m not running any power adders
Thanks, new to fifth gen
RGC1 is offline   Reply With Quote
Old 06-26-2025, 08:07 AM   #2
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
LSA clutch won't work because LSA crank is 8 bolt so LSA flywheel is different than LS flywheel. I believe throwout bearings are the same, but not certain on that. McLeod, Monster etc. are probably a better choice.
Old 06-26-2025, 08:07 AM   #3
Pops
Drives: 2010 Camaro SS2 2012 C6 vette M6
I like the Mcleod RST
Pops is offline   Reply With Quote
Old 06-26-2025, 07:19 PM   #4
CamaroDreams76
Tri-County Camaro SWFL
CamaroDreams76's Avatar
Drives: 2013 IOM 2SS/RS/1LE
No as stated its a different flywheel. Years ago a pretty prominent member ran a centerforce dyad clutch on his twin turbo camaro and basically it burnt up immediately and couldn't handle the power even though it was well rated for it. Also he complained about the clutches engagement. Then when he tried to warranty it, centerforce basically told him the clutch burning up was his fault and denied the claim. So I say pass on them.
I have a McLeod RXT in my car. Its pretty good. Takes some getting used to because of the need for more throttle input when taking off from a stock but overall its super smooth. I would recommend the RST which is a much more street friendly clutch. That is if you dont want to surpass the 700/800whp range.
Stock throwout bearings are fine with aftermarket clutches. Monster has their own upgraded stock bearing.
Old 06-26-2025, 08:20 PM   #5
RGC1
Thanks guys for the information, very much appreciated McLeod it is , thx
