Old 06-29-2025, 03:16 PM   #1
350lover
Drives: Camaro & '62 C10
Knocking noise & intense vibration in shifter
https://www.youtube.com/shorts/R8zdSEDS7K4
2013 Chevy camaro 1LS
There is an intense vibration in my shifter whilst I drive particularly in a low rpm and at low speeds, and it smooths out when I am above 30mph however it is still there to some degree. It initially started off at a vibration at around 5K rpms however it has worsened into this terrible knocking noise as seen in the video whenever the clutch is released. The camaro still drives at regular speed and the clutch does not seem to slip whatsoever. I have no idea what this could be, and I hope it's not the motor as I kept oil in it, any ideas?
350lover is offline   Reply With Quote
Old 06-29-2025, 08:09 PM   #2
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Well I can say it's not the motor, otherwise it would do it with the clutch in or out. I would be checking your throwout bearing, or flywheel..And the clutch discs..And since the car isn't moving, or is it in the vid, that would rule out the drive shaft if it isn't.
Old 06-30-2025, 08:15 AM   #3
fz4k98
Drives: 2013 1ss
If it does it in neutral while pushing clutch in and out it will be isolated fom flywheel through input shaft of transmission.
fz4k98 is offline   Reply With Quote
Old 07-04-2025, 07:47 PM   #4
350lover
It does it in neutral as well whenever I press down the clutch the sound deafens or completely goes away. What does that mean exactly? Am I safe to assume my transmission is fine and its an external component like throwout bearing or clutch or something?
Old 07-05-2025, 08:57 AM   #5
fz4k98
Drives: 2013 1ss
When pushing on pedal in neutral, all rotation stops after the flywheel. It could still be something in the transmission input shaft area. Until it comes apart, it will not be able to accurately diagnose the issue. Happening in neutral does eliminate the rest of the drivetrain though.
Old 07-05-2025, 04:47 PM   #6
bsn
Drives: 2013 ZL1
My money is on the throw-out bearing.
bsn is offline   Reply With Quote
Old 07-05-2025, 08:51 PM   #7
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Yeah. I had a 1969 Camaro with the Muncie 4sp, and when my TO bearing went out, it did the exact thing. Vibration and all..
Old 09-13-2025, 08:20 AM   #8
rockrau
rockrau's Avatar
Drives: 2010 2ss red LS3
Is the driveshaft bearing shot?
Pedders Pace Car Kit with ZL1 sway bar conversion & camber bolt kit.Lowered 1.5". 1LE tires & wheels. CAI air intake. Anvil CF rear spoiler.MGW shifter. 1 7/8" Kooks LT headers & HF cats.V-Max ported TB. Tuned.
rockrau is offline   Reply With Quote
