![]() Drives: 2010 Chevrolet Camaro SS Join Date: Sep 2019
Temps feel insane???
219F on the highway at 80mph
It's Phoenix too, so it's around 118 in the afternoon, feels like my car shouldn't be this hot? Cammed, long tubes, Vararam ram-air intake, Mishimoto aluminum rad, mishimoto oil cooler and separate transmission cooler. Running the car with the heat on to vent more out of the engine compartment. I really don't know what is going on. Is that temp anywhere near normal for cammed cars driving more than 20 minutes on the highway?
2010 Camaro 2SS/RS:
Cyber gray matte wrap, Danti Lambo style louvers, Granatelli Pro-stock look wing B&M transcooler, Mishimoto oil cooler, Mishimoto catchcan, Borla/Pypebomb axle back L99 to LS3 conversion, Vararam ram air intake, BTR Nightfury cam, Johnson lifters, LS7 injectors, Circle D 3200 stall converter, Kooks LT headers, Custom X-pipe |
#2 | |
Tri-County Camaro SWFL
What thermostat is in your car?
My oil temp will go high (like 220ish) if im getting on my car continually because my turbos are oil fed. Coolant temp though is around 185ish.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Turbo LS3 Join Date: Dec 2009
Are both your fans working. One of my fans likes to melt connectors so I put a 60amp connector on it. It is right next to the downpipe.
Turbo car with 160 stat runs 180-190. Vert with stock stat will run 200-210. Neither had aftermarket oil coolers or trans coolers and that is in town, not highway. I do run SuperCool in the turbo car and the tune turns on the fans sooner. It does help.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. Gen6 ZL1 brakes. |
#5 | |||
2010 Camaro 2SS/RS:
#6 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro SS2,L99, LSA SC Join Date: Aug 2017
Need to confirm coolant level of course. How long since the radiator install? Could be air trapped in the coolant system. But 118 is up there and I don't think the heat index has the same effect on cars as people.
#7 |
Something is definitely up. Check coolant as stated. No reason it should be that hot especially with a 160 thermostat and that Mishimtoto radiator. Maybe the thermostat went bad and isn't opening?
#8 |
Will Cave
Drives: 2010 Victory Red 2SS LS3 Join Date: May 2023
May also be worth making sure your coolant temp sensor is working properly.
#9 |
![]() ![]() ![]() ![]() Drives: 2012 Victory Red LFX Join Date: Dec 2012
Yeah i think I'd being shooting it with a temp gun to confirm that's a correct reading.
'18 SS wheels, Heritage grille, actual driving lights, ZL1 strut tower brace, GM Performance billet aluminum fuel door, painted red rotors and calipers, 1/4 window American Flags, splash guards, AEM dry panel air filter.
#10 | |||
2010 Camaro 2SS/RS:
#11 |
![]() ![]() ![]() ![]() ![]() Drives: 2014 2SS/RS 6SP Ashen Grey Join Date: Aug 2021
160 does help but eventually the heat will catch up to it, If this temp issue just started I would be looking into the head gasket issue, Have coolant checked for presence of Hydrocarbons, and oil checked for coolant. Doesn't take much of a leak to affect cooling system. Of course check to make sure thermostat and rest of cooling system is working properly as well.
GM 3.91/TrueTrac OEM ZL1 Rims, 6 Piston Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, GC Aluminum DS,Stainless Works Ceramic LTH/HiFlo Cats, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace, Moroso Catch Can,SCT X4 Dynosteve,Remote Clutch reservoir,Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights
AeroForce Dual gauge/Autometer pillar mount. |
#12 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 CGM 2SS/RS LS3 Swapped A6 Join Date: Sep 2016
Edit: Just read that you already did all of this. Next thing I would do would be to re-burp the system for air pockets. These cars can be very difficult to get the air out of the cooling system.
#13 |
And another thing to check I forgot about, what brand t stat are you using? I see you have a Mishimoto rad, are you using their 160 t stat? If so, myself and another member on here have had failures with the Mishimoto 160 t stats, andwe both went to the Summit one with good results..
#14 | |||
2010 Camaro 2SS/RS:
