Old 07-08-2025, 12:58 PM   #1
hcch
Camaro SS
hcch's Avatar
Drives: 2010 Camaro SS LS3
looking for best belt options
Hi I just noticed a sound coming from the short belt, it does not seem to be cracked, but I am thinking on geting new ones just in case.
I wonder if anyone can suggest a high performance options?
I have Gates RPM on my Stratus turbo, but does not seem to find the part for the camaro.
Thanks in advance
K&N CAI, NGK Ruthenium Sparks
Taylor Cable - 409 Spiro Pro Ignition Wire
Chevrolet Performance axle back
Mishimoto Oil Catch Can, Thermostat, Radiator Hoses
Bilstein shocks and strus
RST Stainless Steel Brake Lines
Drilled and slotted rotos, Akebono break pads
hcch is offline   Reply With Quote
Old 07-08-2025, 02:09 PM   #2
gtstorey
Short belt as in the AC belt?
Old 07-09-2025, 02:04 AM   #3
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
What kind of sound?
The '10s and '11s for some reason was bad for jumping a rib on a pulley and would make a noise until you pushed it back on.
Old 07-09-2025, 05:32 PM   #4
hcch
Camaro SS
hcch's Avatar
Yes
Old 07-09-2025, 05:33 PM   #5
hcch
Camaro SS
hcch's Avatar
Originally Posted by Mr_Draco View Post
What kind of sound?
Let me TRC upload a video I took
Old 07-10-2025, 09:03 AM   #6
gtstorey
AC Belt is a "stretch to fit belt" so probably not going to find a "performance" belt for the application. And if you do you will have trouble installing.
