Old 07-12-2025, 11:14 PM   #1
Steverado
Steverado's Avatar
Drives: 2010 Camaro 2SS/RS
Miscellaneous Parts
Miscellaneous items for 5th Gen Camaro’s
Boosted Items $200
I would like to sell it all as a package deal.
May separate a few of the bigger items.
78mm titanium turbo blanket (new)
2 60-inch 5-foot turbo oil feed lines, braided hose and A/N fittings (new)
Assorted vacuum/ boost hose and fittings (new)
3 valve MAC valve (new)
4” x 2” throttle body to air intake pipe coupler.
3” Metco valve cover breather and misc. 2” breathers
Misc. A/N fittings 6- 8- 4 slip on and twist on
Misc fuel or vacuum line connectors (new)
Misc. Factory Items $100
ECU holder bracket
Map sensor
Oxygen Sensor extension harness
2 oxygen sensors
Gas cap (switched to a yellow E85 cap)
Windshield washer pump
Oil pan level sensor
15 Factory lug nuts
Misc factory hardware, bolts, nuts, connectors
Misc Exhaust Clamps $25
3” clamps, 3" slip fit, 2 1/2" clamps universal hangers, 3" v-band clamp
All of the Above $250 or will sell things separate
Speed Dawg Shifter ball TR6060 6 speed pattern new never used, will fit MGW, Hurst and a threaded shifter handle $45
8 NGK BR7EF spark plugs (new) $20
Steverado is offline   Reply With Quote
Old 10-31-2025, 11:32 AM   #2
Steverado
Steverado's Avatar
Bump
Old 12-21-2025, 12:15 AM   #3
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Would you sell gas cap???
Orange Krush II
Old 12-27-2025, 09:11 PM   #4
Black 13 Maro
Drives: 13' Black 2SS/RS
I’ll take the plugs ��
Black 13 Maro is offline   Reply With Quote
Old 01-19-2026, 02:26 PM   #5
Steverado
Steverado's Avatar
Sorry
olblue75 and Black 13 Maro
I haven't been on here in a while, I will send you both a PM and see if you are still interested
