Old 07-15-2025, 12:43 PM   #1
void_kp
void_kp's Avatar
Drives: Chevrolet Camaro Z28 (2015)
question about oil drain plug gaskets
hello folks,
I've tried several gaskets for the drain plug on the Z28 , last one I tried was https://www.amazon.com/dp/B0CGDNBT7D...n_title_1&th=1 , previous ones were from autozone... but they don't seal as good as the stock ones.
Which ones are you using? where do you buy them?
2015 Red Z/28.
Seattle area
void_kp is offline   Reply With Quote
Old 07-15-2025, 01:01 PM   #2
Coz3z3
Drives: 2015 Z/28, 2015 1LE
I switched my plugs out to the Gold Plugs. They have washers I replace every time I do an oil change. Can buy directly from them or on Amazon
Coz3z3 is offline   Reply With Quote
Old 07-15-2025, 08:50 PM   #3
void_kp
void_kp's Avatar
would you mind sharing a link? I also replace the gaskets at every oil change and I replace oil every 2 trackdays... so I use many gaskets
2015 Red Z/28.
Seattle area
Old 07-16-2025, 07:19 AM   #4
Coz3z3
https://goldplug.com/products/ap04/
If you search that AP-04 part number it should be on Amazon. Then the extra washers is SW-01. I believe its a 5 pack. Should be on there as well
Old 07-16-2025, 03:19 PM   #5
void_kp
void_kp's Avatar
thank you very much!
2015 Red Z/28.
Seattle area
Old 07-16-2025, 10:01 PM   #6
Coz3z3
Absolutely! Hope they work for you like they do me!
