Old 07-17-2025, 04:06 PM   #1
sbelyo
Drives: n/a
What tool is best for replacing the LSA accessory belt?
I'm going to swap my water pump out and see that the belt is a stretchy one. Since the crank supercharger pully is in from of it I don't think the standard ones will work
sbelyo is offline   Reply With Quote
Old 07-17-2025, 07:05 PM   #2
VChula
SoCal C5 Family Member
VChula's Avatar
Drives: 1996 Z28 SS & 2014 ZL1
Only the AC belt is the stretch type.
The LSA actially has 2 belt tensioners - one for the supercharger belt and another one for the water pump/alternator belt.
The tensioner for the water pump belt is just to the right of the supercharger tensioner.
All you need is a breaker bar with a 1/2 square drive for the supercharger tensioner and a 15mm socket for the other tensioner.
Vance Chula -
1996 Camaro Z28 SS #1688
2014 Camaro ZL1 Coupe #1956
VChula is offline   Reply With Quote
Old 07-18-2025, 02:26 PM   #3
bsn
Drives: 2013 ZL1
As was said above no special tools and pretty easy. New belt will probably be tight but it will go on.
bsn is offline   Reply With Quote
Old 07-23-2025, 07:50 PM   #4
sbelyo
Drives: n/a
Thanks... I thought I needed that tool
Old 07-24-2025, 07:16 AM   #5
el ess A
Older Than Dirt
el ess A's Avatar
Drives: 2010 & 2013 Camaros
Tool is not ABSOLUTELY necessary for the A/C belt, but it makes the job much easier. With much less risk to damaging the ribs on the belt. I never understood why people will spend a zillion dollars on other car parts, yet not spring for a few bucks to have a tool in your tool box to make your belt changes so much easier.
2010 2SS TE, 1 of 822/2013 Camaro ZL1 vert, 1 of 54
http://www.camaro5.com/forums/image.php?type=sigpic&userid=26108&dateline=142898  4774
el ess A is offline   Reply With Quote
