Old 07-19-2025, 11:27 AM   #1
0stones0
It don’t come easy.
0stones0's Avatar
Drives: 2010 2SS RS M6
Best key fob replacement
I know this thread has been done other times but, a lot of those fobs are no longer being offered.
I’m looking to replace a 4 button fob case with one that will accept the circuit board AND the my original key (switchblade). Whether by using my original entire rotating key assembly or the key itself which can be put into the new fob, via the pin.
Anyone done this lately and have a link to a fob shell? Don’t care if it has a logo, just want it to accept my parts.
Thanks
The button I never push is the one that disintegrated, with the rest not too far behind.
0stones0 is offline   Reply With Quote
Old 07-19-2025, 12:37 PM   #2
DRC69
DRC69's Avatar
Drives: 2011 2LT/RS
Thumbs up
This guy online did a great job.
Took a pic (HD) of the key.
Bought 3 complete FOB with New cut keys ALL worked like New.
ALL programmed and worth the small price tag. JMO
Midatlanticlocksmith
DRC69 is offline   Reply With Quote
Old 07-19-2025, 01:24 PM   #3
myold88
myold88's Avatar
The Battery & Bulbs store had my FOB in stock. See if there's one near you. They had
me all set with 2 new FOB's for my SS in an hour. Franchises all over per their web site
Old 07-19-2025, 01:37 PM   #4
0stones0
It don’t come easy.
0stones0's Avatar
Checked that option, as well. $120 vs. I get the case and put my guts in it. Maybe $20. Do you know if what you got from (Batteries Plus) was an OEM thing or a better aftermarket? Don’t want that same deteriorating foam that was in the stock ones.
Old 07-19-2025, 04:56 PM   #5
CamaroDreams76
Tri-County Camaro SWFL
CamaroDreams76's Avatar
Drives: 2013 IOM 2SS/RS/1LE
https://a.co/d/eVx3f3g
I personally used this one, swapped the guts out and reused the Chevy emblem. This is my DD use fob below. Original 2nd key i never use.
https://a.co/d/5gUIXwl
Old 07-19-2025, 05:30 PM   #6
0stones0
It don’t come easy.
0stones0's Avatar
Thanks for links. Appreciated.
Were you able to swap out both the board and the key on those?
Thanks
Old 07-19-2025, 07:55 PM   #7
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
This is the same fob I used when I changed mine over to as well, though I bought mine off e-bay for $10 for 2 fobs.
For me, the circuit boards fit except for one spot of the circuit board had to be scraped by a razor blade to remove about 1/32nd on an inch so it would snap shut. The circuit boards aren't all exactly the same size so you might not have this issue.
The key part is just held on by a very small roll pin, I forgot the exact size. All you have to do is punch it out and you can swap it over easily. You can see the pin I'm talking about in the pic. It's in the 2 o'clock position above the spring.
All in all, took me longer to get the old fobs apart then to switch everything over.
Old 07-19-2025, 11:30 PM   #8
0stones0
It don’t come easy.
0stones0's Avatar
Sounds easy enough. I’ll get a couple ordered and give it a go.
Took the bad OEM one apart earlier today. PIA but, doable.
Thanks for the help.
Old 07-20-2025, 03:59 AM   #9
CamaroDreams76
I was able to swap the board and everything keeping the switchblade and all. No modifications at all. I did change the battery just because.
Old 07-20-2025, 09:07 AM   #10
0stones0
It don’t come easy.
0stones0's Avatar
Good to know.
Thanks
Old 07-21-2025, 12:58 AM   #11
TheBrightSide
Drives: 2010 Chevy Camaro 2SS coupe (MT)
It’s honestly easier to just get a whole new keyblade fob made. You have to be very peculiar with searching for key fobs, since a lot of these are easily made aftermarket, and lots of them suck as well.
It took me a while to find some nice aftermarket ones, with the logo in the back. The logos/badges looked fake immediately as you checked them out up close. I ended up buying separate donor keys, and then removed the badge and tossed the rest (was sometimes a trashed key shell/fob).
It’s like $25-35 here around where I live, in order to match a key blade cut. And to program these key fobs… SUPER easy. If you don’t already know, just keep a working key or keyblade fob, use it to turn the ignition all the way to ‘ON’; and then immediately remove it and use the newly cut key to turn it to the same ignition position. Assuming there aren’t NINE whole keys registered in the ECM or whatever, you should have a fresh new key enrolled, and it should give you a message saying so.
If possible, either upgrade to the flat-edged “BMW” styled key fob, or the one that has rounded edges. Those TWO other style of aftermarket key fob upgrades, are much more durable, with no soft rubber keys to wear and tear. Only downside is no logo, and people will immediately know they’re replica keys (who cares..?).
If you want to keep the original key fob style, get the ones that have a set screw. This will prevent the halves from coming apart, which the super cheap OEM replica key fobs may sometimes do. And best thing aside from that, is to have a key fob case, like a silicone one. Might be ugly, but that’ll keep the buttons from getting jacked up….
TheBrightSide is offline   Reply With Quote
Old 07-21-2025, 10:08 AM   #12
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
Totally not true.
It's so easy to switch the guts from one fob to another. I bought 2 genuine GM fobs on ebay for $10 for the set and had everything switched over in less time then it would take me to drive to the closest dealer that can make a new key. My dealer wanted $100 per key, $50 for the fob and $50 to cut it.
$200 vs $10 and 30 minutes of my time makes just changing it out yourself a no brainer.
Old 07-21-2025, 11:54 AM   #13
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
I actually had an Amazon unit fail, and I put the original stock guts in it and it's still working like a charm.
Old 07-22-2025, 07:17 PM   #14
0stones0
It don’t come easy.
0stones0's Avatar
And we’re go. Everything fit right in. Original key pinned. Case held together with 3 small screws. Put my own spin on not having the chev logo.
