Old 07-19-2025, 08:37 PM   #1
davidgonzalez
Drives: 2015 Camaro ss
Question Squeak noise coming from driveshaft
What’s up everyone, so currently im experiencing a problem coming from my front near my front driveshaft coupler, I sprayed the couplers with wd40 and that had removed the squeak sound for about 24 hours, So I figured it was my couplers. I replaced both of them and am still hearing the same noise. Any ideas? Its when I brake, hit bumps, and accelerate so basically all the time.
davidgonzalez is offline   Reply With Quote
Old 07-19-2025, 08:55 PM   #2
Parts Peddler
Drives: 2014 1LT/RS
I would check the various suspension bushings.
Sent from my SM-S921U using Tapatalk
Parts Peddler is offline   Reply With Quote
Old 07-20-2025, 11:30 AM   #3
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Also, never use WD40 as a lubricant as it contains solvents to clean and penitrate, it will wash off any great or oils that are there and dry things out! Use a good silicone lube of sorts for that. I know this from experience when I worked in a machine shop, WD4,,bad...
advice or opinions, help please, mechanical problem
