Old 07-21-2025, 01:17 AM   #1
TheBrightSide
Drives: 2010 Chevy Camaro 2SS coupe (MT)
C8 Corvette Stingray OEM wheels on 5th gen Camaro
I recently acquired a set of OEM Chevy C8 Corvette Stingray OEM factory wheels for cheap. I’ve seen a few 6th gen Camaro owners run this setup, with the factory tire sizes from the C8 Corvette. Those guys had to relocate their ABS sensor in the rear, I believe; but that was roughly about it. I wanted to run these, but with a bigger sidewall (proportion).
The C8 Corvette Stingray wheels are 19” diameter in the front, and a 20” inch wheel in the rear. Front is a 19 x 8.5” wheel, with a +52 offset, and the rear is a 20 x 11” wheel, with a +64 offset. Front tires are 245/35R19’s, and the rears are 305/30R20’s. I wanted to get bigger tires, to basically be similar to the factory wheelsets that I ran.
In this case, I was going to run 245/40R19’s up front, and 305/35R20’s in the rear. I just didn’t know if the increased tire (sidewall) sizes would end up causing me to rub on the supension shocks and struts. I’m still on the factory suspension, so I’m not lowered or anything, and I believe the larger tires I wanna run on the C8 Corvette Stingray wheels, will basically be fairly close to the same 5th gen Camaro V8 20” factory wheel setups I ran.
If any of you have messed around with this setup, or knows anyone who has, please let me know. I have also pondered acquiring an extra pair of front or rear wheels, although the front wheels aren’t all that impressive specs wise, and the rears have such a high offset, that they probably won’t fit in the front, let alone function…
TheBrightSide is offline   Reply With Quote
camaro, corvette, stingray, tires, wheels
