Old 01-31-2010, 01:18 PM   #1
lamontoclese
Drives: 2010 Camaro 1LT
Engine Temperature Gauge
I've only had my Camaro about 1 month and bought it certified used. Everything is good on the car except I noticed that the engine temp gauge doesn't go to the middle temp but stays in between cold and middle. Is this a normal occurrance?
Keep in mind I used to drive a truck and once the engine was warm and running, the gauge would go to the middle.
lamontoclese is offline   Reply With Quote
Old 01-31-2010, 03:05 PM   #2
Top Thrill
BOD 5/28/09 #13485
Top Thrill's Avatar
Drives: 2010 Camaro 2LT RS
NORMAL. If you want to check you can bring up the engine temp on the DIC ( this is the display that is between the speedo and tach) scroll through the display useing the controls on the turn signal stick.
Top Thrill is offline   Reply With Quote
Old 01-31-2010, 03:15 PM   #3
flyby
Drives: 2010 Silver SS
normal, I also think that a lower temp is better which is why people are changing to 160 degree thermostats.
flyby is offline   Reply With Quote
LS3 engine specifications Tran Wiki 3 10-06-2010 11:56 PM
LLT engine specifications Tran Wiki 2 03-29-2010 11:06 AM
Tuning for dummies Milk 1027 Tuning / Diagnostics -- engine and transmission 43 03-17-2010 09:06 AM
P0300 Misfire Code Help black-knight 4th Generation Camaros 4 02-08-2010 02:45 PM
Engine break in methods two_wheel_mayhem Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 39 08-19-2009 10:22 AM
