Old 07-25-2025, 04:14 PM   #1
zz430camaro
zz430camaro's Avatar
Drives: 2015 1LE
spun MAIN bearing sound
What does a spun main bearing typically sound like? I am getting a strange sound coming from my cammed LS3, not a knock and its only at idle, starting to think its a lifter wheel or a bearing going bad.
2015 1LE, TSP 225/236 113+3, VMAX Throttle Body, CAI with race scoop, GPI Ported Intake, Land Speed Stage 2 Heads, 1-7/8 headers, NPP exhaust, 25% Fluidampr, LT1-S Monster Clutch, 485 RWHP & 444 TQ
zz430camaro is offline   Reply With Quote
Old 07-25-2025, 05:08 PM   #2
zz430camaro
Drives: 2015 1LE
Well, i pulled the oil filter and cut it apart and found some metal particles in it, not alot but they were there. Its eating a lifter or a bearing, first thing is to pull the heads and see if a lifter wheel is coming apart, hopefully I caught it in time and did not screw up the engine too bad. Still has perfect oil pressure and no knocking just a weird humming noise at idle.
Old 07-25-2025, 10:47 PM   #3
joshnmn
2&THEHIT
joshnmn's Avatar
Drives: 5th Gen Camaro; 5th Gen Ram 3500
Our damaged lifter made a weird noise too. Hard to describe but definitely caused it to run poorly and throw codes. Is yours running fine?
joshnmn is offline   Reply With Quote
Old 07-26-2025, 01:48 AM   #4
zz430camaro
Drives: 2015 1LE
Ya runs fine, just makes a weird noise, sucks
Old 07-26-2025, 06:48 AM   #5
bsn
Drives: 2013 ZL1
A bearing generally doesn't make any noise except for a knock, my money is on a lifter.
bsn is offline   Reply With Quote
Old 07-26-2025, 09:08 AM   #6
zz430camaro
Drives: 2015 1LE
Lets hope, maybe I can get away with a new cam and lifters
Old 07-28-2025, 06:08 PM   #7
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Good luck, hope that's all it is...
