Old 07-28-2025, 09:56 PM   #1
slipknotdude
Drives: 2013 Camaro LS
2013 LFX - MBRP Muffler Delete, what else?
Hey all, recently installed the MBRP Muffler Delete on my Camaro. Not that I was expecting much out of it but it sounds a little silly/obnoxious, kinda ricey, but I was wondering what else I should be doing to it? Read through a couple threads on Reddit and the only thing I found was to put a MagnaFlow X-Pipe in place of the stock H-Pipe, already got that in my shopping list. Just wanna know any other possible mods that might help improve the sound, my pops (he owns a hotrod shop) suggested a cold air filter before anything.
Also another thing I was considering was downpipes, but last I checked that costs 1 grand...
slipknotdude is offline   Reply With Quote
Old 07-29-2025, 07:54 AM   #2
IOM2013
Drives: Chevy Camaro, GMC Denali Q-steer
I have a 2013 as well and have been exploring options. Mine already has a K&N CAI, and it does give it a nice growl when you get on the pedal or downshift at lower speeds.
On the exhaust side, I have not yet heard anything that I would be willing to spend much money on. All of the exhaust systems seem to be too high pitch.
If I am getting the correct info, the factory V6 exhaust is 2.5" to the H-pipe, then 2.25" from there back with 3.5" tips.
The V8 SS uses a larger 2.5" pipe back to the mufflers. In theory, a larger diameter pipe should lower the tone of the exhaust a little vs stock. The SS exhaust systems are cheap to buy as most people remove them and replace with something louder. I realize the downpipes are slightly different and it would require a little plumbing there but I think it might be interesting to try and would love to know if anyone has tried a factory ss exhaust on a v6 and what the result was.
IOM2013 is offline   Reply With Quote
Old 07-29-2025, 08:26 AM   #3
Indian_Mack
Indian_Mack's Avatar
Drives: 2013 Chevy Camaro 1LT
I did something similar at first and had the same silly ricey sound.
I went with some Hi flow cats, since we can't do headers on the lfx. Straight Stainless pipes without crossovers to the rear, where there's Borla touring mufflers.
Seems like you're looking for loud. I'd recommend doing the Hi flow cats, and putting in and in-line baffles. The baffles would act kind of like a resonance chamber without cutting out too much sound. Bigcitythunder.com makes 2 1/8 ones, and freddomperformexhaust makes 2.5 inch ones. You could slide into the pipes to cut down the rice.
Here's what mine ended up sounding like...
https://youtu.be/CNgaSJQ9br8?si=D1gxqBzqdcwlQyzh
Indian_Mack is offline   Reply With Quote
Old 07-29-2025, 02:06 PM   #4
Lacpac
Lacpac's Avatar
Drives: 2012 Crystal Red Tintcoat RS
Some added the resonated crossover pipe and said the sound was incredibly better.
Lacpac is offline   Reply With Quote
Old 07-29-2025, 02:46 PM   #5
slipknotdude
I'd like loud yes, but at the same time I'm not sure if I'd be able to get a good sound while being moderately loud. Also any videos of how yours sounds under load? Like drivin down a street, aggressive accel, etc.?
Old 07-29-2025, 02:49 PM   #6
slipknotdude
As far as putting a factory ss exhaust on a v6 goes, I'm pretty sure it's practically the same thing past the downpipes/headers. Though I could be wrong, another thing is there was a guy who had put v8 setup on his v6 (although his was a 6th gen, which uses the LGX so not sure how well that'd line up for an LFX) and it sounds pretty good. Just a bit of a mix n match of parts.
Old 07-29-2025, 08:06 PM   #7
Indian_Mack
As a matter of fact, yes. Here's a track day as an example.
https://youtu.be/-XXSpHs293A?si=Y0RZF33WCoY8yAv3
Old 08-01-2025, 01:05 AM   #8
slipknotdude
Sounds very nice!
Old 01-11-2026, 04:08 PM   #9
slipknotdude
Quick thread revival- I've been puttin some more thought into this. Figured I'd like to try and do somethin somewhat custom, but what I'm thinking is replacing the h-pipe with an x-pipe, stick a Black Widow Venom 250 muffler behind that and then a couple Kooks mufflers in the back. Too much? Not enough?
May have to copy/paste link in a new tab
file:///C:/Users/gavin/OneDrive/Pictures/Screenshot%202026-01-11%20150539.png
Old 01-12-2026, 12:02 PM   #10
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
One thing I can say about this, in all my readings and research in any system the X will give you a more "raspier", exotic note, where the H will give you a more lower "growlier" note. Many videos out there depicting that. You might jsu want to do a Magnaflow resonated mid muffler, and nothing behind that, or like one of my buds did, I gave him my old Dynomax Ultraflo Welded mufflers for his V6, and it sounds great!
https://www.phastekperformance.com/C...pipe-11386.htm
https://www.dynomax.com/mufflers/ult...elded-mufflers
Old 03-26-2026, 09:07 AM   #11
Quick Turkey
Drives: 2015 Camaro 2LS
Folks say the x-pipe will make it raspier but I didn't really notice a difference. I had a muffler delete on mine for about a year before replacing the factory h-pipe with a Magnaflow muffled x-pipe (11385lt made the car quieter but still louder than stock while improving the tone and getting rid of most of the rasp from the muffler delete.
I wanted it a little louder so I got rid of my secondary cats which didn't make too much of a difference, but now I could hear a bit of a burble when decelerating. Recently I got rid of both resonators and it's definitely a little louder now but some of the rasp is back.
Eventually, I will delete the primary cats since I can tune them out and will add two Vibrant ultra quiet resonators where the factory resonators were to tame the rasp.
Quick Turkey is offline   Reply With Quote
