Old 08-03-2025, 11:22 PM   #1
350lover
Drives: Camaro & '62 C10
Exclamation Pilot bearing on 3.6 LFX is mated with the AY6 or not?
Got a new clutch kit for my 13 3.6 with a AY6 but it seems i cant line up the clutch, i figured thats weird and it hit me that my transmission does not have a pilot tip after the splines on the input shaft. How can this be? Im running a single mass flywheel. Do i just eyeball the alignment? Is something wrong w the transmission?
Also wondering how the current pilot bearing is sng one side being worn out and the other fine if nothing is mating with it?
350lover is offline   Reply With Quote
Old 08-04-2025, 05:27 PM   #2
TheBrightSide
Drives: 2010 Chevy Camaro 2SS coupe (MT)
I don’t know this too well, but don’t the 10-11 RS V6 and 12-15 RS models use a different clutch and flywheel kit? Have you checked what kind of clutch/flywheel kit you got? Or did you end up getting a factory OEM setup or OEM spec replacement? I figure it might not hurt to check, since I see a lot of online vendors and parts search engines and databases, listing the 10-11 RS as having a different clutch kit, compared to the 12-15 RS models.
TheBrightSide is offline   Reply With Quote
