Old 08-04-2025, 12:15 PM   #1
TheBrightSide
Drives: 2010 Chevy Camaro 2SS coupe (MT)
Rear main seal cover/gasket replacement
I was looking for a generic replacement for the rear main seal cover, on the LS3 on my Camaro. Looks like GM OEM parts numbers 12633579 and 12639250 will fit? What’s the difference on these? It looks like they fit most LS style 4.8L, 5.3L, 6.0L, and 6.2L V8 engines. I’m just not sure whether the SUV/truck applications are a bit different from the passenger car parts.
Also, should I just replace the rear main seal gasket itself, or the cover gasket as well, while I have my transmission dropped and out? I figured I was gonna eyeball underneath the clutch and flywheel; but since I may be considering replacing those as well, I’m most likely just gonna replace all the rear main seal gaskets for peace of mind…
If anyone knows anything else I should check/replace while I have my trans dropped, please let me know. I’m currently replacing my clutch slave cylinder, and I’m also installing a remote bleeder line on it. Other than that, I can’t really think of anything else I might be missing, apart from a billet release bearing support that I threw onto the new CSC.
TheBrightSide is offline   Reply With Quote
Old 08-04-2025, 07:26 PM   #2
InFiD3ViL
InFiD3ViL's Avatar
If you already have the trans out I would also do the cover gasket. No point in ignoring that when you are right there.
Old 08-05-2025, 02:41 PM   #3
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
And a special note from my experience, make sure to be careful when removing the rear cover as it does contact the oil pan gasket on the rear corners. One of my "used to be" techs didn't see that when he replaced my cover and rear main, and in removing the cover, it took a chunk of the oil pan gasket with it and didn't seal back up, soooo I had ANOTHER leak back there after a while! They did fix it for free since it was THEIR fault.. Just had to put some RTV in the spots where the gasket was torn and missing..
Old 08-08-2025, 12:18 AM   #4
TheBrightSide
I will keep this in mind. I have my factory oil pan gasket currently leaking from the sides a bit… I remember the oil pan gasket requiring RTV gasket maker on the 4 corners, but I’ll check what might need me to use some gasket maker on the rear section of the oil pan gasket. Should I use Permatex Ultra Gray or Ultra Black? Those are what I’ve used in the past for oil pans.
Old 08-09-2025, 11:20 AM   #5
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
I'm not sure what they used, but you want it to harden, yet stay "flexible" like the rubber gasket material is on the cover and pan. Not the gooey black pasty crap we used back in the day. The crankcase pressure will blow it out if it gets too much.
Old 08-10-2025, 08:28 AM   #6
Joe.G
Joe.G's Avatar
Drives: 2014 2SS/RS 6SP Ashen Grey
Ultra Black is meant for oil pans, Holds up to Heat and oil better than Grey which more for Water pumps and thermostats and what not. I Have used RTV colors for applications they aren't suggested for and have not had an issue but I try to keep about 10 Different types on hand.
LSA SBE, Kong Ported LSA SC Reinforced Brick DM Billet Coolant Manifold with NW 103, ID 1050X,Roto Fab Big Gulp, 2.55 Upper 5% ATI Lower. AFCO HX, ProSpeed AUX Tank, MM Wild Catch Can SW Ceramic LTH/NPP, ZL1 FP JMS BAP, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace,3.91/TrueTrac Monster Triple Clutch OEM ZL1 Rims, 6 Piston Brakes & Side Skirts.ACST4 Splitter/Deflectors
783 HP 720 TQ on 93 Oct.
Joe.G is offline   Reply With Quote
Old 08-10-2025, 09:01 AM   #7
tartagliazl1
tartagliazl1's Avatar
Drives: 2013 zl1 vert
Not sure on the different covers. Maybe think about replacing the plastic dogbone seal with a new one or a metal one.
22% lower/ 2.5 upper/ 2” headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 1300/ dsx aux kit/ 103mm throttle body/ big gulp 5” intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2” lid spacer/ cnc,milled ported heads/ brick mod/BMR toe and trailing arms/ 781hp 748 tq SAE @17.3lb on a loaded dyno.
tartagliazl1 is offline   Reply With Quote
cover, engine, gasket, seal, transmission
