Old 08-06-2025, 05:03 PM   #1
dudamota
dudamota's Avatar
Drives: Twin Turbo 5th gen Camaro
advice with Hood Louver
Hi,
I need advice for my Twin Turbo Camaro 5th Gen.
I need to release the hot air from my engine bay.
What about buy this =
https://racelouvers.com/camaro-10-15...s-street-trim/
it is worth to try ?
Thank you.
dudamota is offline   Reply With Quote
Old 08-06-2025, 08:13 PM   #2
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
They are similar to the Hines Hex Vents I had in my stock hood, that aren't available anymore. They will work for heat extraction, plus you could remove the rear rubber weather strip on the cowl area under the hood, some of us have done that, it will also allow heat to get out while driving. Plus the vents and the weather strip removal will do away with the negative pressure under the hood in the engine bay that tends to want to "lift" the front end up under high speeds.
Old 08-07-2025, 01:35 PM   #3
dudamota
dudamota's Avatar
Thank you for the tip about "remove the rear rubber weather strip on the cowl area under the hood"
I just removed mine. Clearly I see some air now can flow on the back of the hood. For sure it will help a bit.
Any downside to remove this ? Maybe in rain ?
I also saw this = https://www.summitracing.com/tx/part...1hl-b/overview
Not sure it will fit in my 5th Gen Hood. The ones from racelouvers.com does not look aesthetically the best ones, but it appears to have the best performance. They do the wind tunnel to prove it.
I will need for sure a pair of those. A LOT hot air is comming out from the hot part of my turbine. I will need to install just bellow them.
Check image.
I am not sure about the central hood louvers. I guess for now I will only install those for the side. Should I also do the front one ?
[/IMG]
Old 08-07-2025, 02:48 PM   #4
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
Try TracSpec vents. I researched a lot after I found out the Hex vents were unobtainium and TracSpec are the ones that appeared to be the highest quality.
Old 08-09-2025, 12:36 PM   #5
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Check image.
[/IMG]
No issues driving in the rain with the rear strip removed, but I don't drive her in the rain if at all possible, and if you are referring to the front weather strip, no don't remove that one, it won't help at all, plus it cushions the front of the hood from vibrations...
Old 08-10-2025, 12:10 AM   #6
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Hood Vent
Go with this one, I have it on mine looks ridiculous!!
https://trackspecmotorsports.com/pro...7da6a1ba&_ss=r
Orange Krush II
Old 08-10-2025, 06:18 PM   #7
dudamota
dudamota's Avatar
Yea I only got the rear one removed and like I said I noticed already a low temperature in my hood.
But I am afraid in the future about rain.
As I will install those 2 =
https://trackspecmotorsports.com/col...-center-louver
https://trackspecmotorsports.com/col...1-side-louvers
Old 08-10-2025, 06:20 PM   #8
dudamota
dudamota's Avatar
Yea.. I bought the same.
And also = https://trackspecmotorsports.com/col...1-side-louvers
When you say "ridiculous" you mean ridiculous good or ridiculous bad ??
Old 08-11-2025, 10:45 AM   #9
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Now that's a killer looking vent!!
Old 08-11-2025, 10:48 AM   #10
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Flipped it for ya..
Old 09-14-2025, 01:23 PM   #11
dudamota
dudamota's Avatar
So it is installed.
Bought from here =
BUT, I must tell you guys that "trackspecmotorsports.com" inform = availability: Many in stock
After I bought, I had to wait many many days so they can send the louvers.
https://youtu.be/rR1eyLKeUw4?si=QPd48y692gmS7FB0
Can anyone confirm if I can drive my car using this hood vents when raining ??
Old 09-14-2025, 05:21 PM   #12
0stones0
It don’t come easy.
0stones0's Avatar
Drives: 2010 2SS RS M6
So it is installed.
Bought from here =
Nice work, great result!
0stones0 is offline   Reply With Quote
Old 09-14-2025, 07:56 PM   #13
CamaroCracka
I drive mine if I get caught in the rain with the two side vents. I also don't have the center vents. I also use a 1400psi pressure washer to clean the engine bay and it does not seem to bother anything.
I generally don't drive my car in the rain because my tires suck in the rain and I hate doing body work. With twin turbos, I personally would not make a habit of cruising around in the rain.
Old 09-14-2025, 09:01 PM   #14
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Very nice work duda!!! Looks killer cool! That will really help get a ton of under hood heat out for sure. You should be alright IF you get caught out in the rain. All the wiring and connectors under the hood are supposed to be moisture resistant according to GM, so they say. But like cracka says, I wouldn't make it a habit of driving around in the rain, especially if it is raining pretty hard, and with twin turbo's..
