SS
Hi, I replaced drivers bearing and half shaft one side only because of lack of local nuts and seals. All sphohn delsphere tightened car feels tight again. A opportunity to race car is fast approaching and feel it should be ok to run car with the stock ss passenger side in play as they are uneven wieghts from differing lengths to start with Am I delusional?
CCW sp16a track set, BTR stage 3 cam and kooks longtubes with high flow cats
SS
Oops the drivers side is now the 1LE half shaft
So you running a 1LE shaft on one side and a SS shaft on the other?
Orange Krush II
SS
Not driving it yet but want to, yes
